Predator & Vig 3200--'02 F-body
Old Jul 15, 2003 | 12:13 PM
WJ SOM SS's Avatar
Default Predator & Vig 3200--'02 F-body
Anyone using a Vig 32-3600 converter on a '01-'02 F-body working w/Predator? Is it deleting TM any? Anyone also using this combo w/out a shift kit using Predator to change line pressure-shiftpoints? Results? Good or bad....Thanks. WJ.
Old Jul 16, 2003 | 03:09 PM
WJ SOM SS's Avatar
Default Re: Predator & Vig 3200--'02 F-body
No one using this combo? Any help appreciated. Thanks. WJ.
Old Jul 17, 2003 | 11:44 AM
2002blackZ's Avatar
Well, since no one else is responding... I am using a 3000 RPM Midwest stall with Predator. It has gotten rid of all of my TM. I didn't increase the line pressure, just the shift duration.
I read that increasing pressure could cause problems. I figured that reducing the time to shift would help keep the heat down from less friction.
Hope that helps
Old Jul 17, 2003 | 12:39 PM
BOOSTEDTA's Avatar
and supposedly the base tune on the Predator already adjusts the line pressure somewhat*. i'm a little fearful myself so i only have it adjusted slightly. is it the general consensus then that you can reduce the shift time to the max and not harm the tranny?
Old Jul 18, 2003 | 07:23 AM
WJ SOM SS's Avatar
Thanks. Anyone else have anything to offer on this? WJ.
Old Jul 21, 2003 | 03:50 AM
Kansas 99z28's Avatar
I have a vig3200 and the predator on a 99 Camaro. On my 1-2 shift time I have it set to -8.750% on the shift time and added 10% line pressure. On my 2-3 I have it at -8.500 and have the pressure at 10% also. I left the 3-4 shift normal cuz I dont normally have it to the floored that long to need it to shift fast into it. Hope that helps you out a bit.
Old Jul 21, 2003 | 06:28 PM
Jpr5690's Avatar
how much of a gian did you all see after doing your converter?
Old Jul 22, 2003 | 01:25 AM
like 2-3 tenths. not the .5 like they advertised
Old Jul 22, 2003 | 08:14 AM
2002blackZ's Avatar
I went from a 13.2 to a 12.6. I figure it was a combination of the TC, Predator, and a muffler. Very happy with the stall though.
Old Jul 24, 2003 | 06:42 PM
WJ SOM SS's Avatar
2002blkZ: You did all the mods at the same time? 12.6 in cool, or hot weather? I've been 12.82, 109.5, 1.92 sixty w/stock converter, Nitto's and HPP3 in 50 degree weather. My best w/Predator and same mods has been 12.90, 108.1, 1.95 sixty in 70+ degrees. Getting ready to install the Vig 3200 w/no shiftkit----just Predator w/the 3.23's. I'll be using my 8.5x15 ET Drags, though. Hoping for low 12's w/some cooler weather. I run at a sea-level track in New England....WJ.
Old Jul 24, 2003 | 06:55 PM
WJ SOM SS's Avatar
I have: '02 A4 SS, 3.23's, T/A cover & studbolt kit, boxed lca's, lca re-location brackets, rt. side airbag, '95 Camaro V6 rear springs w/heater hose on top coils--no top rubber, 275x17" Nitto's, 15x4 Convo-Pro fronts w/skinnies, LG d/s loop, LG 2&3/4" Y-pipe, Gutted cats w/02 simms, SLP dual-dual exhaust w/Flo-Tech cutout in int. pipe, ASP pulley, Donaldson 345 hp factory lid w/FTRA. 160 stat, stock heads, cam, and everything else. Vig 3200 still sitting on bdrm floor..... 2800 miles on car. WJ.
Old Jul 25, 2003 | 10:19 AM
2002blackZ's Avatar
WJ, I did the Predator, muffler, and stall all within about a week of each other. The Predator and the stall came in about the same day. I had my uncle weld in the muffler 3 or 4 days later. Then I went to the track the next weekend. I ran a 12.7 at 107 with a 1.8 short time in bad weather. IIRC, the DA was around 2200. Not sure what that means exactly, but the temps were around the low 80's and pretty high humidity.
I went back to the track just last weekend and ran the 12.6 at 108 with a 1.8 60'. The weather was a little better. Around low 70's. Lower humidity. With 50 degree temps this fall, I'm hoping for a 12.5 with the same set up. The track I run at is around 500' above sea level I think.
Old Jul 25, 2003 | 03:19 PM
WJ SOM SS's Avatar
2002: Do you have a trans cooler, or deep pan? I forgot to say that I have a TCI plus 2 qt. pan on my car as well. Will install a 19,000 gvw cooler beside my FTRA when I do the converter. Best wishes and keep me posted w/your success or your shortcomings.... WJ.
Old Jul 26, 2003 | 09:20 PM
2002blackZ's Avatar
I run a Hayden super cooler. Don't remember the exact size. It's about 8" x 12". Keeps the tranny about 20 degrees cooler according to ATap.
I should have some new times this weekend. Just hope for cool dry weather.
Later
