is it ok to leave torque convertor attached to flywheel
Old Feb 16, 2003 | 07:17 PM
redaddiction's Avatar
Default is it ok to leave torque convertor attached to flywheel
Hey guys i guess i took my tranny out and we left the torque converter on there and haven't taken it off but will it hurt anything i did support it with a jack.
marc
Old Feb 16, 2003 | 08:41 PM
MachoTA's Avatar
Default Re: is it ok to leave torque convertor attached to flywheel
um did you scar the sleeve or the output shaft. I would personaly have taken the bolts off the conveter. Also probably should take it off.
Old Feb 18, 2003 | 01:09 PM
Nagash01WS6's Avatar
wow... how did you get it out without taking the converter out as well?????
I had a friend try it... not enough room in the tunnel.
Old Feb 18, 2003 | 01:48 PM
Kevin Steele's Avatar
I am amazed that you got the tranny out with converter bolted to the flywheel. You must take the converter off to properly install the converter in the tranny. The distance from the mounting surface of the tranny (where it meets the motor) to the mounting surface of the torque converter (where the bolts screw in) should be 1 1/8" when the converter is install in the tranny. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> If this measurement is not a least 1 1/8", DO NOT INSTALL TRANSMISSION!! The converter will bust the pump rotor. <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Kevin Steele
