Fitting a 4L60e to LSx - Help!
Old Feb 22, 2008 | 03:51 PM
SheldonZ28's Avatar
Default Fitting a 4L60e to LSx - Help!
Hey Everyone.
Im knee deep in an LS swap into my 89 iroc. I had plans to keep the 700-R4, but it seems its more trouble then its worth.
Im thinking its in my best interest to just pickup a 4L60e. My local yard has:
4L60e from a '97 K1500 2WD pickup
4L60e from a '99 V6 Astro van
The astro van has a removable bellhousing, truck one doesnt. What is needed to be changed between these to make them work behind my LSx motor?
Thanks so much!
Old Feb 22, 2008 | 09:03 PM
LS1MCSS's Avatar
You need a 98 or newer. You will just bolt it up, connect wiring and go, as long as the pcm is programmed for it.
Old Feb 24, 2008 | 10:58 AM
SheldonZ28's Avatar
Your truely are a life saver!!!
Old Feb 24, 2008 | 11:12 AM
performabuilt's Avatar
LS1Tech Sponsor
The 98 up must be from and LSX based aplication, The 99 from the 4.3 will not bolt diectly to the LSX block you would at the very least need a converter pilot adapter like the ones used to install a th350 or 400 to and lsx block.
Your best bet is just to find and LSX based 60e, 98 up camaro/firebird and trucks with the 5.3 and 6.0 engines
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Feb 24, 2008 | 12:36 PM
SheldonZ28's Avatar
Awesome.
Does this mean the output shaft is the same?
Say i were to get a pilot adaptor & an LS1 bellhousing, will this solve my problem?
Thanks!
Old Feb 24, 2008 | 12:49 PM
LS1Tech Sponsor
The tail shaft for a 2wd is the same , the tail housing may be different , And no the LS1 bellhousing you use the lt1 housing and the converter pilot spacer.
__________________
Call 888-744-6542
