shift kits
Old Feb 26, 2008 | 09:21 AM
bigboy t/a's Avatar
Question shift kits
i wanted to know what would be a good shift kit for a 1999 t/a
i wanted one that would be good for regular driving and the accasional racing
Old Feb 26, 2008 | 09:25 AM
brejcha's Avatar
Here is a list of a couple http://www.ws6project.com/user_stor/...bd01f4b1089551
I believe the WS6store is a sponser on LS1tech...if not I am sure I will be hearing from a moderator soon.
I would go with the TRANSGO shift kit. The price is right and you will like the performance.
Old Feb 26, 2008 | 12:52 PM
RevGTO's Avatar
Pontiacerator
Transgo HD-2. Look no further. Consider no other.
Old Feb 26, 2008 | 01:00 PM
firebirdman469's Avatar
I actually have a brand new in box Transgo HD-2 that I am selling. I bought a built Transmission so I don't need it anymore. PM me to talk about it.
Old Feb 26, 2008 | 03:33 PM
AK's WS6's Avatar
Yup, transgo HD2 is the way to go. Great mod and buy the way you describe what you are after 1 washer for firmness is the way to go.
Old Feb 26, 2008 | 07:02 PM
bigboy t/a's Avatar
i think i will go with the transgo kit
how much are u selling it for?
Old Feb 27, 2008 | 11:47 AM
I would let it go for $85 shipped. If Paypal is used, add 3% for fees. Let me know via PM.
-James
Old Feb 27, 2008 | 02:36 PM
omcar's Avatar
Just remember that you may have to have your torque management deleted.
Old Feb 28, 2008 | 04:37 PM
AK's WS6's Avatar
Maybe, i'm on a stock tune and it still runs pretty damn hard.
Old Feb 29, 2008 | 04:00 PM
chargedvx6's Avatar
I suggest you get pinless billet accumulators too. Foward billet, 2nd oem alloy with a longer runner, 3-4 billet.
Old Mar 1, 2008 | 04:46 AM
PBA's Avatar
PBA
The "modified" TransGo Shift kit has three new aluminum accumulator pistons with seals, hardened (RC52) forward & 2nd accumulator pins, new oem accumulator pin for 4th, Torlon checkballs, separator hole sizes to go with the torque converter, rear end gear ratio you are using, how you drive, etc.
Old Mar 1, 2008 | 06:47 AM
chargedvx6's Avatar
In Australia there is a low/ no availability of this kit. Apols.
Just trying to give a heads up for the newbie on shift kits. Once u go to the trouble of taking it al out, might as well do it once the right way.
Old Mar 1, 2008 | 11:32 AM
SVT THIS's Avatar
Do you have a stall converter? If you don't have a stall converter **** a shift kit and get a stall converter. Best mod I ever did on my stock LS1. Full bolt ons, full weight 200lb drive, 4400 stall, 2.73 gears and ET Streets took me into the 11s. 3500 stall w. a transgo HD2. If you wanted some more fun you could go w/ full manual valve bodies =)
Old Mar 1, 2008 | 11:54 AM
angel71rs's Avatar
Recommend you replace the seperator plate as long as you're going in there, ~ 20 bucks at local trans supply shop. Read this thread so you understand why I recommend it:
https://ls1tech.com/forums/automatic-transmission/658369-installed-shift-kit-my-thoughts-long.html
