Owners of A4 with 3.73's need to know
Old Feb 20, 2003 | 07:09 PM
SS4U2NV's Avatar
Default Owners of A4 with 3.73's need to know
What rpms are you running from 50 to 100 mph.thanks in advance for any input you can give me.
Old Feb 21, 2003 | 02:22 PM
FASST's Avatar
Default Re: Owners of A4 with 3.73's need to know
rpm = (mph * Axle ratio * Transmission ratio * 12 * 5280) / (3.14159 * Tire diameter * 60)
Your axle ratio would be 3.73 and I believe 4th gear in an auto would be 0.74...that might be fifth in a manual, I forget. Either way, that's the equation.
Old Feb 21, 2003 | 08:49 PM
Ragtop 99's Avatar
4L60 fourth is .69 as I recall. .69 or .70
Old Feb 21, 2003 | 10:11 PM
WeatherGuy's Avatar
Top gear ratios on a few trannies:
4L60E - 0.70
T-56 - 0.50
200-4R - 0.67
TH350/400 - 1.00 (no OD)
Powerglide - 1.00 (no OD)
Makes a huge difference in highway RPMs. My car, with the 200-4R and 3.73s, is about 2300 RPM. Pretty livable with the converter locked.
Old Feb 24, 2003 | 05:22 PM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
Here you go, try this out, plug in the numbers, it worked great for a dumb *** like me:
http://www.f-body.org/gears/
SteveC <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 24, 2003 | 05:28 PM
Black Sunshine/ 00SS's Avatar
Umm... Cant drive the car right now, no motor & snow, well you know about that..
From memory, I am at 2400 @ 70 mph. Get back with me in the summer and I'll check again. I'm sure it's going to depend on what convertor you have. I have the Vig 3600 right now.
What convertor do you have right now?
Old Feb 25, 2003 | 08:15 PM
SS4U2NV's Avatar
i had the yank 3200 but it killed 3 yes 3 transmissions ,so i put the stock one back in.Give me a bump in the month of May we will be renting out miland on the second thursday of each month from 6-9 pm for ***** and grins
Old Feb 27, 2003 | 12:50 AM
35th SS's Avatar
have it on the 35th but speedo not calibrated yet so kind of off like 10mph.guessing.
Old Feb 27, 2003 | 06:53 PM
kent's Avatar
My A4 with 3:73's run 2300 RPM's at 70 MPH. I checked mine yesterday because I am having 4:10's installed I am verifying the increase in RPM's with these gears. I hope these new gears help some at the track.
