Just Installed Spec Stage 3 clucth... damm hard!
get yourself an adjustable master if you aren't happy with the current engagemnent point.
My buddy has the same problem. The clutch engages right at the top of the pedal push. Instead of at the bottom, like stock. We tried to adjust it with his McCloud Adj. Master, but NO go.
I don't think a adjustable master cylinder, adjust engagement point. My buddy installed a twin disk McCloud w/ Adj. Master. We could only get the Master Cylinder to adjust pedal position, Not Engagement point.
Adj. Master Cylinder's only adjust Pedal Position? Is this right. I Hope we were doing somthing wrong Because I want to adjust the Engagement point.
Thanks
Thanks
