shift point question, with a twist
Old Mar 5, 2008 | 10:39 PM
dab2pds's Avatar
Default shift point question, with a twist
i need to slow my car down a bit at the track. i have gotten too fast to run without a cage, and i need to slow down to run the points series because i refuse to put a cage in my vette at this time(daily driver). i have hpt and i commanded the 1-2 shift to 5000 and 30 mph, which worked great. i commanded the 2-3 to 5000 and 60 mph, which did not work at all, it still ran out to 6600. this has me pulling my hair out right now, because when i manually shift the car, it runs out to the commanded rpm before it will shift, and not as soon as i shift. Any ideas? 2004 a4 corvette with RPM level V transmission and 3600 vigilante convertor. runs 11.0X all out on motor, and i need to slow it to 11.60ish, and the track wont let me run to the eighth and lift, i'm getting speed warnings for that too :bang
thanks, Dave
Old Mar 5, 2008 | 10:48 PM
GregWS6&z28's Avatar
as much as you dont want to, the cage is really a good idea. i dont think you will be consistent by making the car shift slower. run the car to the max of your setup
Old Mar 5, 2008 | 11:06 PM
performabuilt's Avatar
LS1Tech Sponsor
You would need to drop both the shift MPH and RPM the MPH may have to be set really low
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
