A4 problem after cooler blew a line
Old Feb 23, 2003 | 05:06 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default A4 problem after cooler blew a line
I have a 02 SS with a built A4 Vig 3600 verter(customer car)After doing a bunch of work I took it for a spin.About 2 miles away I see smoke out the back of the car.Pulled right over and shut the car off.Noticed tranny fluid all over the ground which was caused by a line blew off a straight metal connector(Customer work <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" /> )Hooked back up the line and put 6 quarts in it and limped it home.At my house I put in 3 more quarts(dip stick sucks to read)and took it out for a ride.
Now first gear grabs good,seconds stalls to 3000 at part throttle and has a lazy shift to 3rd.When you manual shift it the gears slam and lock real good <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> Like it was doing before the line <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
It did have a engine light caused by a pressure solinoid that I cleared but haven't driven since.
Any ideas? I don't think the tranny is gone.
Old Feb 23, 2003 | 06:00 PM
Dave Rockwell's Avatar
Default Re: A4 problem after cooler blew a line
Hey Slowhawk, Hang a gage on it, see if your line rise is immediate, and responsive. If not, pull the valve body, replace the EPC screen, while your there drill(.060 X 2) through the bottom of the screen to prevent this in the future.Debris plugging the EPC screen or maybe the EPC selinoid needs relaceing, I change them both when symptoms like youve expressed happen.I hope this helps.
