Need some help, trans is stuck!
Old Mar 8, 2008 | 03:39 PM
Luna's Avatar
Default Need some help, trans is stuck!
Ok guys, I'm yankin the auto for a T56 but its stuck. I got all the bolts out, TC bolts are out, TC is pushed back. The trans seems to be stuck on the alignment pins.
We've tried heatin' them up, spraying lots of PB blaster on them, and generally shaking the **** out of the trans in all directions. What else can we do? It hasnt even budged at all. The bellhousing is still FLUSH with the motor!
HELP!!!!
Old Mar 8, 2008 | 04:06 PM
FLT's Avatar
FLT
Takes two people to be safe. Remove the starter. Take a long pry bar and get up in the starter pocket. Find a place to pry between motor and the trans. Do not pry on the flex plate! Lower the jack until there is very little tension on the jack. Have one guy pry and the other start to wiggle by holding on the tail of the trans. A few choice curse words along with this procedure normally work. Are you sure that you have all of the bolts removed? Not trying to be a jerk but it happens. Here is a photo of all the holes that should have bolts removed. I have circled them here in red.
Old Mar 8, 2008 | 04:13 PM
99Hawk262's Avatar
I used the exact method that Vince outlined above and it finally came off. Just be patient and keep working at it. Be careful so you don't gouge any metal. Be gentle when prying and it'll finally slip off. Good luck!
Old Mar 8, 2008 | 04:21 PM
Luna's Avatar
Thanks for the tips. After looking at that pic I'm positive we've gotten all the bolts out.
What if I've already been prying on the flexplate ? ... alot.
Nothing needs to go back onto the car as I'm swapping in a T56, that auto is in **** shape anyway.
Old Mar 8, 2008 | 04:27 PM
FLT's Avatar
FLT
Guess it doesn't matter if your not reusing it. Missed that part. I think the block is a little more solid. Just be carefull as to where you pry as mentioned above. Let me know if you are looking to get rid of that a4.
Old Mar 8, 2008 | 04:29 PM
Luna's Avatar
I definitely will need to get rid of it. Its not in much shape for anything other than a rebuild, the fluid that came out of it was BLACK and the thing shifted like ****. Shoot me a PM
Old Mar 11, 2008 | 05:08 PM
Luna's Avatar
Fought that bitch some more today.... it still wont come off....
Old Mar 11, 2008 | 06:19 PM
Luna's Avatar
Can those pins be replaced if drilled out ? I think they may be mushroomed on one end.
Do they stay in the motor or the trans?
Old Mar 11, 2008 | 06:22 PM
heymoej's Avatar
i had 1 pin stuck in the motor & the other pin stuck in the trans............
Old Mar 11, 2008 | 07:16 PM
performabuilt2's Avatar
LS1Tech Sponsor
get a ratchet strap and hook to the back of the tranny and to the rear diff and ratchet it off it will come off
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
Old Mar 11, 2008 | 07:33 PM
Luna's Avatar
We started to do that but got nervous when the tq arm started movin around. Is this safe to do ?
Old Mar 11, 2008 | 07:54 PM
BlackZ28629's Avatar
large prybar...its just seized/frozen
Old Mar 11, 2008 | 07:56 PM
Luna's Avatar
lol, a bigass prybar is one of the first things we tried!
Old Mar 14, 2008 | 09:23 PM
Luna's Avatar
The gold star goes to performabuilt!
We hooked up a chain hoist to the rear and around the tail shaft and got it as tight as possible. Gave it a few good cranks with the pry bar and POP! she goes
Old Mar 15, 2008 | 08:09 PM
LS1Tech Sponsor
glad to help had to do this a few times when i worked at the chevy dealer I ahd a special strap for it lol, Oh yeah I have dealer experience lol not just a salesman
__________________
