siezed forward clutches?
Old Mar 17, 2008 | 10:12 AM
spy2520's Avatar
Default siezed forward clutches?
on a 4l60e. When put in reverse it feels like the brakes are on, car still moves in reverse. But it needs a little "help". Any other symptoms to this? And if the forwards are holding in reverse that must mean the reverse clutches are getting pretty tore up too right?
Old Mar 17, 2008 | 10:27 AM
performabuilt's Avatar
LS1Tech Sponsor
Yes it will damage the low reverse and reverse inout clutches if you keep trying to go in reverse like that. does it also try to move forward in neutral and park?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 17, 2008 | 10:48 AM
spy2520's Avatar
not that i have noticed. You've seen my other thread though, do you think a pressure issue could cause the forward clutches to hold in reverse, but not actually be seized?
I had already mentioned that reverse was weak, and it all of a sudden became almost impossible to back up, so i'm thinking that this has been the problem since the trans went in, and reverse finally lost the fight.
Old Mar 17, 2008 | 10:53 AM
LS1Tech Sponsor
Well if the forward clutces are seized you would try and pull forward in neutral would feel like 1st gear, Now a bind up in reverse could be a crossleak in the valve body or pump . Low line it self would not cause that, I would check and make sure it does not try and go forward in NEUTRAL for sure
__________________
Call 888-744-6542
Old Mar 17, 2008 | 11:12 AM
spy2520's Avatar
just double and triple checked it does not go forward in neutral or park, even if i give it some gas, it does not move forward at all in neutral o park. But it definitely feels like the brakes are on in reverse.
And i did notice something odd when installing that i guess i didnt pay much attention to, but when tightening the bolts on the u-joint, i could only turn the driveshaft one way by hand with the car in the air, but i did put it through all gear positions in the air when the installation was done and everything seemed normal at that point, of course there was no load though.
Anyway, i'm not gonna have a 4L60e manual with me, but i'm gonna pull the pan and check out the valve body at work today and hopefully there will be something noticeable.
Old Mar 17, 2008 | 09:13 PM
spy2520's Avatar
Ok, i got bad news. The fluid i just put in on tuesday is definitely full of clutch material. I think i saw some shiny **** in there too. And i checked on the lift, guess what happens when i put it in neutral? the ****** wheels spin as if its in first gear.
It makes perfect sense i guess, i have a 4000 stall converter, so it would take a little more effort for the car to want to roll forward when its on the ground. Being that the converter is so loose, i shouldnt be able to feel the car pulling a little in neutral. But in the air it does, so i guess it is the forward clutches.
I think i'm gonna rebuild the other trans in my spare time, so i guess i need to call and get some parts soon.
Old Mar 17, 2008 | 10:19 PM
LS1Tech Sponsor
Just saw you said that the drive shaft would only turn one way and that would explain every thing , The 2-4 band clearance was too tight this would cause all the symptoms you mentioned.Good luck on your try again and if you need any advice feel free to holler.
__________________
Call 888-744-6542
Old Mar 18, 2008 | 09:15 AM
spy2520's Avatar
really? i never would have guessed that judging by how the 1-2 shift felt. And the band cant be adjusted externally like those older ones i guess.
Old Mar 18, 2008 | 09:20 AM
spy2520's Avatar
And i couldnt find anything in the valve body that looked out of place as far as i could remember how the 4l60e valve bodies were supposed to look. All valves moved as they should, and all the springs were in there to the best of my knowledge. I would have liked to know exactly how the vacuum modulator was supposed to be on there though.
Old Mar 18, 2008 | 09:21 AM
LS1Tech Sponsor
No it can be ajusted with shims and with pin length, But it being burned, would explain the bind up in reverse. Its either to tight or theres some hydraulic leak thats turning it on in reverse.
__________________
Call 888-744-6542
Old Mar 18, 2008 | 09:26 AM
spy2520's Avatar
ah i see. Well i cant wait to take it apart and see how a $2 part could have saved a $2300 transmission lol.
Old Mar 18, 2008 | 09:28 AM
LS1Tech Sponsor
Keep us posted ,
__________________
Call 888-744-6542
Old Mar 18, 2008 | 09:33 AM
spy2520's Avatar
i will, you'll probably see the inside of the other trans first though. Burned 3-4 clutches, nothing interesting.
Old Mar 18, 2008 | 10:06 AM
spy2520's Avatar
i got one last question for you. If the trans has no fluid the possibility of a hydraulic issue applying the 2-4 band isnt very likely right? i wonder if its worth trying to mess with the servo in the mean time.
Old Mar 18, 2008 | 10:12 AM
LS1Tech Sponsor
That would be correct
__________________
Call 888-744-6542
