swappiing a 700r4 to th350 on a camaro
If you use a long tail (9 inch 350) you can use th original drive shaft if not you will have to shorten drive shaft three inches. you will need to move cross member and relocate the torque arm. May I ask why you are switching to a 350 your going to loose alot drivability wise.
__________________
Well a TH350 is IMO not alot stronger than a 700r4 have you gotten a trans from a sponsor here or someone who specilazes in built 700r4 transmissions?
__________________
