TH350 Conversion - DS Question
Old Mar 21, 2008 | 12:30 PM
Stroked96Bowtie's Avatar
Default TH350 Conversion - DS Question
Im doing a TH350 conversion on my LT1 car, will the stock driveshaft work if I use the 9in tailshaft version and have a M12-bolt?
Ive read alot that it will work with a stock style rearend, but cant find anything about the aftermarket rearends.
Old Mar 21, 2008 | 02:02 PM
dlove's Avatar
did you read my faq?
the trannsmissions are very close to the same lenght. if it works now, why wouldnt it work with another tranny of the same lenght
Old Mar 22, 2008 | 10:31 AM
C_B64's Avatar
Not sure, but I do know you will have to change u-joints to make it work with a moser 12 bolt
Old Mar 22, 2008 | 08:00 PM
JaSSon's Avatar
It will work good enough to drive it, but when you hammer it there is too much flex. It doesnt go into the tailshaft enough. I broke 2 tailshafts learning the hardway. I had Denny's make a custom fit 3.5" aluminum. It does cost though.
