'LOOSE with High Stall'
Old Jul 25, 2003 | 04:05 AM
4thGENRETARD's Avatar
Default "LOOSE with Hi Stall"
I keep reading 'My car is a bit loose with my Hi Stall TC' What do they mean by that???
Planning to get a Street Fighter 3200 (YANK)
Old Jul 25, 2003 | 06:13 AM
Rok's Avatar
Rok
Default Re:
I'm not positive because I'm an M6'er but I think you can lock something in the converter, and if that something isn't locked in the converter is "loose".
I may be way off but that't what I think it is.
Old Jul 25, 2003 | 09:45 AM
boos2's Avatar
Default Re:
Try posting this question in the automatic transmission section. You'll get an answer there.
Higher stall means higher RPMs to get the car moving. You'll get a better answer from the guys who use converters. I drive a M6 so I'm not familiar with all the details.
Old Jul 25, 2003 | 12:22 PM
SuperZ28's Avatar
Default Re: "LOOSE with Hi Stall"
"loose" is a term used to describe the feeling when a car is reving but it doesn't seem like it's moving much....usually higer stalls and lower gearing will make a car feel loose.
I see you have 3.73s, those and a 3200 stall will be just fine!
also, each converter has a rated STR ( stall torque ratio )
the higher the STR the harder the car will hit from a stop.
If I wanted to get a 3500 stall and my car only had 3.23s..I would try and get a converter with a higher STR to make the car feel less sluggish off the line, or less "loose"
Hope this all makes sense!
Old Jul 25, 2003 | 12:53 PM
dand35th's Avatar
Default Re:
the feeling of slippage.
Old Jul 25, 2003 | 06:06 PM
Default Re:
Thanks guys and superZ I understand and I see the light
Old Jul 26, 2003 | 07:26 PM
SNAXS's Avatar
Very Well Said!!
