Converter holding me back?
60' is not my problem, just my mph. Mods are ms4 cam, ls6 intake, pandp tb, 3.73's, longtubes, true duals, lid, a good tune, and a midwest 3400 stall. I'm not sure of the weight of the car, but I have no weight reduction, only taken out the spare tire and jack. I've ran a best of 12.0@114mph, but that was with a -400 DA and BEFORE I added a better tune, 3.73's, subframe connectors, and DR's. I am running better ET's than before in similar weather.....but the mph hasn't changed. I was almost certain that with 3.73's my 3rd gear would be in the powerband better. But now I'm suspecting the converter.
I added the converter while I still only had a couple bolt ons. I figured it would be enough of a stall for the cam....and it is.....but I'm sure now I'm not getting the most out of my setup with the stall. It just seems like it is VERY inefficient in the top end. What do you guys think?....is it the converter "slowing" me down? Hell I've seen bolt on m6 guys trap better than 112 mph in similar weather, lol.
I'm pretty certain tax refund check is gonna supply me with a new yank pt4000 if ya'll think my converter is holding the car back.
....or maybe a PT4400 (probably won't run nitrous....and by the time I do I'll be running a new setup anyways.)
60' times are worse even on ET Streets. Question for the short time is,
are the DRs enough? I don't think so.
Can you see the TC slip RPM as you run through the gears? Look at
the slip RPM as fraction of engine RPM. I'd say if you slip more than
5% at 6000RPM you could gain from efficiency. My old TCI made 3%
(3000 stall) and my Fuddle (3500) is just coming down to 5% there.
But I have locked / unlocked logs showing it's still multiplying torque
past 5000RPM. The slip % is only a rough indicator of efficiency. But
if you slip without multiplying torque that is juat a waste.
I'd think with that cam you ought to have a pretty flat torque line
and could shift pretty high. Basically shift as high as the springs
and pushrods can take. The converter gets more efficient the more
RPM you run.
You're going to be really happy with a TP4000.
