Transgo HD2 install?
Brad
I'm sure one of our great sponsors will chime in and get you some detailed install instructions.
Ok, to remove the valve body, take the car out of park and apply the parking brake, jack the car up on a lift or jack stands.
Remove the pan, fluid and filter.
Unclip all the wiring connections and let the wiring hang, remove the PWM solenoid by taking the clip out with a small screwdriver, remove the TCC solenoid from the pump since it's wires do not unclip and move it out of the way.
Then remove all the bolts, leave one in the middle for last so you can hold the VB with one hand and unscrew the bolt with another. Drop it down and work the link out of the manual valve.
Put it on a clean work surface.
For the seperator plate hole sizes, stock converter .082 for second, .093 for all others. Use one shim washer for the second accumulator.
Now refer to something else and remove the transmission.
Remove the o-ring from the input shaft, remove the pump bolts and pull the pump out.
Pull the input shaft/drum assembly out, remove the 3-4 clutch, forward clutch, forward sprag. Use a clutch spring depressor to compress the forward spring retainer. Remove the forward clutch return springs, and replace them with the ones supplied in the kit, remove the 3-4 spring retainer and replace the springs with those supplied in the kit.
Let me know when you get this far and I'll continue.
Oh yea while you're in there check the forward, second, and fourth accumulator pistons if any are plastic order aluminum ones asap so they will be ready for assembly.
This is where the sponsors come in handy because they want your business, you have to buy these parts somewhere, I'm doing this for free.
I would just love to see a sponsor come in this thread and give a write up on how to install this kit from beginning to end? Any one of you guys got the time?
I will guarantee you that WILL NOT HAPPEN.
But still let me know when you get the trans apart and we'll continue this. You're going to need to buy a clutch spring depressor so that should take a few days to come in, I'll be waiting.
Frank at PerformaBuilt 570-578-5686
I don't build transmissions for a living and I've always installed the complete kit no matter which trans I was putting one in. Never had a problem with the instructions either though.
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2
Click Banner for Website.Not Just Built.....PerformaBuilt!
I would definitely recommend that you shouldn't attempt the install until you have studied and comprehended the instructions fully. Once you have dropped the pan it isn't the time to be working things out.
The best tip I can give you is to do with refitting the valvebody at the end if the install. Follow the sequence in the vid for refitting to the letter and I don't think it can be done in a more appropriate sequence.
Get some Vaseline because it will be your friend during the install. Everything that is a contact surface needs the Vas.
Plus if you read the OP's other post he's got a pan and filter full of metal already.
https://ls1tech.com/forums/automatic-transmission/658369-installed-shift-kit-my-thoughts-long.html
Any ETA on that write up?
PS, trying to put a hook in our lip to write up in "detail" the correct installation won't get any responses either. This would litteraly take 5-8 hours of typing and then another couple to proof read to make sure of perfection. The public demands it!!
JFWY Rob!
