Broken speed sensor harness on tranny
Old Apr 12, 2008 | 02:52 PM
firefighter813x's Avatar
Default Broken speed sensor harness on tranny
I broke the speed sensor on the tail end of the tranny (98 4L60E) when I was installing my torque converter. I didn't break the sensor that bolts into the tranny, but I broke the clip that snaps in. GM wants $94 bucks for that clip!!! Do I have any other option?
Old Apr 12, 2008 | 03:42 PM
FLT's Avatar
FLT
All you need is the plug correct with the wires? $94 for a pig tail? I would check with another dealer.
Old Apr 12, 2008 | 03:44 PM
Yes sir! The plug on the harness has two wires and off of memory I think one is yellow and one is purple?? I can't remember
Old Apr 12, 2008 | 04:11 PM
FLT's Avatar
FLT
That does not cost $94. Tell them to look it up again or go to a different dealer. Might be able to get one from a junk yard.
Old Nov 1, 2008 | 12:25 PM
wajouba's Avatar
If the speed sensor isn't plugged the 4L60e won't get a command to shift true?! because I have just drove my car today for the first time, its a 240sx with an LS1 conversion, and its Auto, but it won't shift to 2nd, but I had my speed sensor disconnected because its not reaching... am I right? or do I have another problem?!
Thanks, sorry for the Hijack
Old Nov 1, 2008 | 12:37 PM
performabuilt's Avatar
LS1Tech Sponsor
No it will not shift or will shift very late without the speed sensor its a must
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 1, 2008 | 03:08 PM
MUSTANGBRKR02's Avatar
try Steve at LSXTune should have these----->
Old Nov 1, 2008 | 03:11 PM
http://www.lsxtune.com/shop/product_...roducts_id/880
this the one?
