TH400 Conversion Q's
Old Mar 12, 2003 | 06:52 AM
Fast SS on TNT's Avatar
Default TH400 Conversion Q's
Going from an M6 to TH400.
What parts are needed?
Price of aforementioned parts?
Part numbers if possible?
This is for a full time drag car. Dont bother with speedometer parts, or any frills. I already have the TH400/Yank Converter/Transbrake/B&M Tranny Cooler. Now I just need the parts to put it in. Thanks in advance!
Old Mar 12, 2003 | 07:09 AM
Tim98TA's Avatar
From: From the Bowels of Hell!!! You want some of me bitch?!?!?!
Default Re: TH400 Conversion Q's
Get a dipstick from MADMAN. A tq arm setup from MADMAN. Get an A4 tranny crossmember and move the mount pad backwards ~2". Get a poly tranny mount. Get a shifter of your choice.
Tim
Old Mar 12, 2003 | 07:13 AM
MADMAN's Avatar
LS1Tech Sponsor
Actually you can use your trans crossmember. I have the dipsticks in stock. $69.95. A a4 flexplate works just fine. You will need a new driveshaft. We sell a 3.5 aluminum shaft with the th400 yoke and solid ujoints for $395.00 Give me a call for more info. 281-449-8833
__________________
www.madmanandcoracing.com
225-343-9029
Old Mar 12, 2003 | 05:05 PM
The TH400 bolts right up to the LS1...no adapter needed????
Old Mar 12, 2003 | 07:43 PM
Tim98TA's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Fast SS on NOS:
<strong> The TH400 bolts right up to the LS1</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yep
Tim
Old Mar 12, 2003 | 09:15 PM
Do you have to shim the flexplate? Does the LS1 starter from an M6 crank a TH400?
Old Mar 12, 2003 | 09:26 PM
cruzerbobby01's Avatar
Yes the starter will work. The only trick is the torque converter you have to add 5/8 inch to the snout.
Old Mar 13, 2003 | 07:01 AM
Tim98TA's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by cruzerbobby01:
<strong> Yes the starter will work. The only trick is the torque converter you have to add 5/8 inch to the snout. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">NOT ALL CONVERTORS. I have heard the most problems with having to shim, have been with the Yank convertors. I have an ATI convertor and tranny, and mine bolted right up, no shimming.
Tim
Old Mar 14, 2003 | 04:06 PM
highgmc's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Tim98TA:
<strong> [QUOTE]. I have heard the most problems with having to shim, have been with the Yank convertors.
Tim </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">my yank pro thruster bolted right up PREFECT, no shimming. on a th400.
Old Mar 14, 2003 | 04:26 PM
I appreciate all the responses. I decided to put off the TH400 install for another month. My main focus right now is installing a Racetronix plug and play setup and new shocks and springs.
For the tranny cooler, what lines do you recommend? And with a 4000 stall, how much heat can I expect the tranny to generate. The last TH400 I had in a 79 Trans Am I had years ago kept cooking itself to death with the big stall. I had to replace the tranny 4 times in one year, and it put me off of automatic transmissions for 12 years!
Old Mar 14, 2003 | 04:29 PM
LS1x2's Avatar
Formerly 4mulaJoe
I ordered a vigi3200 for a th350 from PI. I only had to put some 1/8" washers between the flexplate and converter. I don't she where you would need to do more than that with any other converter.
