torque convter bolts
Old Apr 19, 2008 | 09:35 AM
GregWS6&z28's Avatar
I have a grasp, but when the converter is installed it's spun through 2 grooves to fully be seated. ive seen where the converter has to be spun the opposite way to slide off. maybe that was a different instance.
Old May 10, 2008 | 08:18 PM
007's Avatar
007
Get a oxy-acetiline torch and heat up heads of bolts red. Then they come right out.
Old May 10, 2008 | 11:03 PM
01ssreda4's Avatar
mine slid out the minute the trans tilted forward on the jack. sorry i didn't have to unspin it.
Old May 10, 2008 | 11:13 PM
CamaroRacing12's Avatar
the proper way to do it is to remove the bolts first...
Old May 12, 2008 | 12:47 AM
johnLs1camaro's Avatar
the bolts are torks anyways they arent alan's so thats a lot of the problem and if you already stripped them just weld a standard bolt to them and it will bull them right out
Old May 13, 2008 | 01:26 AM
FrankSS's Avatar
or you can go to town on it with an angle grinder and grind them off... i did that after i heated them up. got a good notch in them and they went after them with the air chisel... worked like a charm
