torque convter bolts
Old Apr 14, 2008 | 09:35 PM
ls1slow11's Avatar
Default torque convter bolts
Im trying to pull my tranny and those bolts that go to the torque convter i cant get loose i got on and strip the other. I got all the bell housing bolts can i just pull the tranny out know even tho those bolts aint out. Help please
Old Apr 14, 2008 | 09:54 PM
Figz Z28's Avatar
If there the stock bolts you might have to chisel them off.
Old Apr 14, 2008 | 10:20 PM
ls1slow11's Avatar
it aint stripped that bad i think one size bigger allen wrench would help. i dont get why these are so tight tho
Old Apr 15, 2008 | 08:50 PM
ls1slow11's Avatar
No one has any ideas i really need to get this tranny out
Old Apr 15, 2008 | 10:40 PM
GregWS6&z28's Avatar
u got all 3 bolts out? try harder. you may have to chisel them off like said, or weld a bolt to it to get it out (thats what a buddy had to do for my car)
Old Apr 16, 2008 | 10:23 AM
ls1slow11's Avatar
will whats the best side to get to them on the pasgnger or driver. Does it help if i jack the tranny up a bit
Old Apr 16, 2008 | 10:56 AM
what? you said you got all the bellhousing bolts out. the converter bolts you have to get out behind the starter.
Old Apr 16, 2008 | 11:07 AM
ls1slow11's Avatar
yea i know but i saw anthor plastic shield on the other side didnt know if i could get to them form there
Old Apr 16, 2008 | 11:53 AM
bluehawk2's Avatar
The space where the starter goes is the only place you can get them out. Those are going to be a pain, but your going to have to get them out in order to pull the trans. put a couple bolts back in the bell housing and go to the next size bigger allen and beat it in with a hammer and hope that works. I have found it is easier to get those bolts out if you jack the transmission back up to get a better angle on those bolts.
Old Apr 16, 2008 | 05:02 PM
ls1slow11's Avatar
HELP please i need to get this tranny out is there any other way to get those bolts out or can i take the tranny out with them still in there or what help please
Old Apr 16, 2008 | 05:30 PM
im sorry but to gauge by your questions you probably shouldnt have tried this swap on your own. you cannot take the trans out with the converter bolts still bolted in
Old Apr 16, 2008 | 07:49 PM
ls1slow11's Avatar
Yea i know i cant i was just hoping i can belive GM put those type of bolts in there cuz they strip so easy and they are so tight in there
Old Apr 16, 2008 | 08:53 PM
use some heat on the flexplate first to try to help loosen the bolts
Old Apr 16, 2008 | 10:13 PM
achilles76's Avatar
I just dropped my tranny over the weekend. Those bolts are a pain in the butt. I went to autozone and got a hex bit socket and put a pipe on the end of the ratchet to get more leverage. My buddy held on to the flywheel with a big screwedriver by the teeth so it wouldn't move but thats because im replacing the flywheel. If you are not i dont recommend the screwdriver part. Did u get the bolts waaaay on top? I had to take the intake off to get to them. But thats because we have fat hands.
Old Apr 16, 2008 | 11:07 PM
CamaroRacing12's Avatar
have a buddy put a 1/2inch socket with a rachet on the crank in the front of the engine to hold it still and rip those bolts out of there! i believe the crank is a 19mm
Old Apr 16, 2008 | 11:46 PM
87silverbullet's Avatar
1 of 2 things take a socket and beat it over the head of the boltand use a ratchet to get it off. If you can't get it that way you going to have to get an air chisel but don't try to knock the head off instead put it to one side of the bolt and try to spin it using the repeated hits of the air chisel. This has worked for me every time.
Old Apr 17, 2008 | 05:27 PM
Marc 85Z28's Avatar
You absolutely can remove the transmission with the torque converter bolted to the engine. I've done it before on many vehicles, including an LS1, that had locked up engines. Just know that the front of the engine will have to be jacked up to tilt the powertrain, and that transmission fluid will go everywhere once the converter is pulled out of the transmission. You'll have to pull and twist the transmission to get it to clear the input shaft and the floorpan.
That said, removing the converter bolts with the transmission removed won't be much easier.
Old Apr 17, 2008 | 05:43 PM
what are you talking about??? the converter bolts to the flexplate on the back of the motor...... i dont think this post makes sense
Old Apr 17, 2008 | 07:56 PM
01ssreda4's Avatar
the converter is bolted to the motor but not to the tranny. if you tilt the tranny far enough down it could theoretically slide off leaving the converter still bolted to the motor. whats so hard to understand about that??????
Old Apr 19, 2008 | 08:26 AM
Marc 85Z28's Avatar
It makes sense if you have any type of grasp of how a torque converter mates with the transmission.
