Trans gets hot when sitting still?
Old Apr 15, 2008 | 10:38 AM
RedDemonLsX's Avatar
Default Trans gets hot when sitting still?
The other day i was picking my daughter up from school and when waiting in line i noticed my trans temp was getting hotter sitting there.It reached i belive 220 and stayed there but once i got moving again it lowered to normal around 180.What causes this?..i have a B&M supercooler,do i need a bigger cooler or deeper pan?
Old Apr 15, 2008 | 11:33 AM
performabuilt's Avatar
LS1Tech Sponsor
Are you running the cooler as a stand alone or through radiator, Dependng on air flow when you are setting still if running through the raditor the trans temp will rise to just above engine temp , Same situaion but slower if you have radiator bypassed if theresno force air through the cooler then the temp will steadily rise whenyou are setting still. A solution for both situations would be a fan to force air through the cooler even when the car is not in motion.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Apr 15, 2008 | 12:56 PM
jimmyblue's Avatar
Moderator
Are your fans still at stock settings? These will let
everything run up to 220+ before kicking on and a
trans cooler with no airflow is helpless. If the cooler
is located off the main stack then the fans probably
help very little, anyhow.
