Car stalls out after converter install
Old Mar 13, 2003 | 09:08 AM
TNT-SS's Avatar
Default Car stalls out after converter install
After I installed my vig.3600, the car doesn't like idleing very well and after pulling to a light it acts like it wants to die and 90% of the time it does die, especially after going from reverse to drive.
What is Wrong?????????
Old Mar 13, 2003 | 11:06 AM
TNT-SS's Avatar
Default Re: Car stalls out after converter install
ttt
Old Mar 13, 2003 | 11:07 AM
TNT-SS's Avatar
ttt
Old Mar 13, 2003 | 11:36 AM
TomQ's Avatar
i don't wanna go deep into details
raise your idle to let's say 750(idle)/850(D)
best of luck
Old Mar 13, 2003 | 11:49 AM
WMSuperSport's Avatar
On stock cam and tuning...?
Old Mar 13, 2003 | 01:22 PM
Colonel's Avatar
You can drill the TB air hole a little bigger or you can raise the "idle air" table a little with LS1Edit.
Your problem is not that uncommon with loose converters. Think about it, your RPMs when you suddenly let off the gas fall from a higher RPM, fall faster, and therefore a little farther before the IAC can make the proper adjustments.
Old Mar 14, 2003 | 12:57 AM
PonchoFan's Avatar
There is an idle relearn procedure on LS1.com.
Mine stalled once or twice right after install but corrected by itself.
Hope this helps.
Old Mar 14, 2003 | 07:16 PM
DrkPhx's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by PonchoFan:
<strong> There is an idle relearn procedure on LS1.com.
Hope this helps. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ditto. My car would sometimes stall in reverse, and the idle relearn procedure helped.
Old Mar 17, 2003 | 12:45 AM
broke7's Avatar
I didnt ever hear the idle re-learn until yesterday after ls1edit changes. Car started up like it had a fat nasty cam in it, cleared up in 10-15 seconds.
Runs pefect now. On the same note I am doing my stall this week, I will let you know if I had problems.
