Synthetic ATF
Old Apr 16, 2008 | 03:51 PM
LS1 Coupe's Avatar
Default Synthetic ATF
Ok Guys, I am getting close to being able to fill the trans with fluid, I have installed a Yank SS3200 in it and will also be doing a new trans filter before I add my ATF. The trans has 28K on it. Yank does not recomend Synthetic ATF, what are your thoughts and what do you guys run in these transmissions for ATF. I use synthetic oil but have never used Synthetic ATF.
Old May 2, 2008 | 11:10 PM
CamaroRacing12's Avatar
im wondering the same thing... hopefully somone will chime in
Old May 2, 2008 | 11:17 PM
LT1-DAN's Avatar
I have always used Valvoline MaxLife ATF in my cars, shifts great and I never had any problems at all.
Old May 2, 2008 | 11:24 PM
Hennytime's Avatar
use the regular, the synthetic is for the newer trans
Old May 3, 2008 | 08:00 AM
Hardtop's Avatar
Just use regular ATF, non synthetic.
Old May 3, 2008 | 08:59 AM
staringback05's Avatar
28k miles isnt that much on a tranny....any particular reason yank said not to use synthetic?....although my tranny was brand new...i dont think id ever use anything else beside dextron 6...
Old May 3, 2008 | 08:00 PM
LS1 Coupe's Avatar
This is what is stated to use on there Tourque Converters. I went to may places around town, no one has just plain Dextron IV, and out of all of these place 2 had it in Synthetic only, everything else was one size fits all BS.
LS1 Coupe's Avatar
This is what is stated to use on there Tourque Converters. I went to many places around town, no one has just plain Dextron IV, and out of all of these place 2 had it in Synthetic only, everything else was one size fits all BS.
Old May 3, 2008 | 08:17 PM
my tranny builder said to just use reg dex 3 non synthetic, i personally would pick a quality brand like castrol or valvoline
Old May 3, 2008 | 10:15 PM
99T/AMAN's Avatar
i just got my trans rebuilt and i am running mobil one syn. trans fluid with the ss3600. Just last weekend my car started not shifting into third at the end of the track under wide open throttle only and is fine on the street though. Could the syn. trans fluid cause this you think. My trans guy put the syn. fluid in the car.
