Noise on 2-3 shift
Old May 8, 2008 | 09:39 PM
kggunter's Avatar
Exclamation Noise on 2-3 shift
I have a 98' T/A with a Trans Go shift kit, and a 2800 stall converter. New after market driveshaft. Problem is on the 2-3 shift and only when going easy on the throtle I get a noise. Something like a dull thud. Under harder accelleration no noise. It could be from the trans or from the rear end hard to say the way sound travels. would this be normal wiyh a shift kit?
Old May 8, 2008 | 09:56 PM
performabuilt's Avatar
LS1Tech Sponsor
Well if you have and aluminum shaft you may just be hearing some noise transfer from a clunk on the 2-3 shift. Without hearing it I am only guessing though wildley
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 8, 2008 | 10:05 PM
kggunter's Avatar
The after market shaft is a steel shaft. Is this clunk normal?
Old May 8, 2008 | 10:06 PM
LS1Tech Sponsor
still just may be some noise lash transfer. Remember 3rd gear is straight through and the 60e with a shift kit is known to be variably kinda clunky on the 2-3 at light throttle
__________________
Call 888-744-6542
Old May 8, 2008 | 10:10 PM
98WsSick's Avatar
i have the transgo shift kit in my car as well I know exactly what your talking about, when I'm cruising slowly though a parking lot is when I notice it. Only 2-3 for me as well.. Must not be anything too serious.. not sure
Old May 8, 2008 | 10:15 PM
LS1Tech Sponsor
Like I said its a common issue with the 60e and a shift kit I wouldnt worry about it.
__________________
Call 888-744-6542
Old May 8, 2008 | 10:22 PM
kggunter's Avatar
Thanks guys for the quick replys. I guess its Ok then. Thanks again.
Old May 9, 2008 | 04:28 AM
chargedvx6's Avatar
I too have the transgo kit and did the 2-3 apply hole a little big in the sep plate. The clunk is probably just the clutches engaging quickly which is the reason I got the kit
Old May 9, 2008 | 09:56 AM
382ssz28's Avatar
What we have found is the timing between the band in second releasing and the third gear clutches applying, there is a slight bind in the shift. We've made the hole for the third gear firmness smaller and most of the clunk is gone. I've had this problem with my own car and I bought a new plate from GM just to try, and it seems to have worked fine. You can tune the trans for a firmer shift when you accelerate harder off the light with your laptop. Hope this helps.
Old May 10, 2008 | 07:37 PM
kggunter's Avatar
Thanks again for all of the great information.
