Trans Cooler Mounting Question Need Help 911
Old May 11, 2008 | 05:36 PM
bigd2001's Avatar
Default Trans Cooler Mounting Question Need Help 911
SHOULD TRANS COOLER BE MOUNTED ON FRONT OF CONDENSOR OR ON BACKSIDE OF RADIATOR?
Old May 11, 2008 | 05:41 PM
FLT's Avatar
FLT
It needs clean cool air. So if possible infront of both pieces.
Old May 11, 2008 | 06:45 PM
01SideShow's Avatar
I just did mine and i mounted it in front of condenser for better cooling. At least that what B&M says in their instructions. Hope this helps
Old May 13, 2008 | 07:18 AM
Johns00Z28's Avatar
what about those of us w/ a FTRA?
Old May 13, 2008 | 10:06 AM
nahasapeemapetalon's Avatar
Front. How would you mount it in the back where the fans are?
http://i173.photobucket.com/albums/w...m/DSC02830.jpg
http://i173.photobucket.com/albums/w...m/DSC02844.jpg
I took out that plastic piece that was in front of the radiator.
Old May 13, 2008 | 08:41 PM
dnkynrbk's Avatar
mount it in the front for the radiator to get as much air as possible. Mine has been mounted that way for 2 years no problems I would also route around your factory tranny cooler and go to bigger afermarket tranny cooler 25 to 28.
