Transmisson Cooler ??????
Old May 17, 2008 | 01:39 AM
70ls1chevelle's Avatar
Default Transmisson Cooler ??????
I have a 99 WS6 automatic,the cooling set up i ran through the radiator and an aftermarket cooler fastened in front of the a/c condenser ! Then i bought and installed an SLP cold air induction stainless steel air box that sits in front of the condenser so i had to temporarily remove the tranny cooler . What should i do ,and where should i put the cooler, since i had to move it ? Should i keep it running through the radiator at all ??
Old May 17, 2008 | 01:44 AM
LiquidFire350's Avatar
should post this in the auto trans section
anyways, https://ls1tech.com/forums/showthrea...ght=style+dope
Old May 17, 2008 | 04:25 PM
SOMbitch's Avatar
Mine is mounted in front of the radiator.
Old May 17, 2008 | 04:36 PM
01ssreda4's Avatar
dope style i guess. you dont have many options. everything is fighting for air on these cars.
Old May 17, 2008 | 08:13 PM
formula4437's Avatar
i modified my sheetmetal intake to make it fit.
Old May 18, 2008 | 12:16 AM
jimmyblue's Avatar
Moderator
I butchered my SLP CAI for exactly this reason and no
regrets. I kept the stub but cut & bent the steel to draw
from above (through) the divider panel in the cool nose
space. I opened up the "nostrils" by cutting away foam.
It does not compromise IATs the way the CAI did (tens
of degrees hotter than the SS hood alone, on the street).
Old May 18, 2008 | 03:19 AM
99blancoSS's Avatar
You could run a radiator with a built in cooler and save on space. I sell Ron Davis radiators for just this purpose.
Old May 19, 2008 | 03:39 AM
Thanks guys ! I got it mounted again
Old May 19, 2008 | 04:10 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Moving this to Automatic Trans just for search purposes.
Old May 19, 2008 | 12:00 PM
Ragtop 99's Avatar
The Automatic has a built in cooler in the radiator. It is inadequate for the job so most add an aftermarket cooler. The other challenge of a built-in radiator cooler is that the coolant is at often up around 190 - 195* so that reduces the efficency of radiator cooling, although an aftermarket radiator may be better designed than the stock one.
