4l60e Tranny not shifting?? Stays in 3rd?
Old 06-13-2008, 12:59 PM
wbwhiteboy's Avatar
I went and made sure the connections were clean, and they lookedd pretty good. I made sure the plug was on very tight.
I take it out for another spin, and it shifts 1-2, 2-3, and just goes back to limp mode.
Im going to get it scaned again here sometime, but its weird? if i shut the car off itll shift 1-2, 2-3 and then go back into limp mode.
Old 06-19-2008, 04:09 PM
wbwhiteboy's Avatar
bumping up, if anyone has any other ideas??
Old 06-21-2008, 08:12 PM
Shon Herron's Avatar
update?
Can some one tell me where the Pin E wire goes from the trans up to where? I do not think it goes to the VCM, E must get it's power from another place, it says circuit 1020, but I can not find where that is located or routed thru the car.
Old 06-21-2008, 08:13 PM
LS1Tech Sponsor
performabuilt's Avatar
Well its fed from the ignition switch and the fuse box but exactly where I am not sure I will research
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 06-21-2008, 08:20 PM
I also have a conversion, 97 Z28 with an 01LS1 engine/harness/A4
Knowing it comes from the fuse panel helps alot. And if you can post up what fuse location that might help.
Old 06-21-2008, 08:27 PM
LS1Tech Sponsor
Hope tis helps
__________________
Call 888-744-6542
Old 06-21-2008, 08:31 PM
So if C100G has 12v, it should be sending 12v to pin E?
Old 06-21-2008, 08:47 PM
LS1Tech Sponsor
I would think so unless theres a wire cut somewhere
__________________
Call 888-744-6542
Old 06-21-2008, 09:09 PM
AH HA!
I think I have found the issue. I will know tomorrow!!
BTW- I hate wiring!! BUT I appreciate your help!!
cross fingers that I have found the problem!
Old 06-21-2008, 09:14 PM
LS1Tech Sponsor
Good Luck and let me know
__________________
Call 888-744-6542
Old 06-24-2008, 09:51 AM
GOT IT!
That diagram you posted helped!! The wiring information we were using didnt match the use of the wire that was not hooked up, but once I got ign power to that pink wire it was good to go! Now time to street tune and hit the track!
THANKS!
Old 06-24-2008, 09:59 AM
  #32
LS1Tech Sponsor
Glad I was able to help out
__________________
Call 888-744-6542
Old 06-24-2008, 10:13 AM
  #33
ME TOO
Old 06-24-2008, 11:34 PM
  #34
wbwhiteboy's Avatar
im still trying to figure out what to do about mine, and what it could be??
Old 06-25-2008, 06:21 AM
  #35
Did you have it scanned and what codes is it showing?
Old 06-26-2008, 08:12 PM
  #36
wbwhiteboy's Avatar
yea i previously had it scanned and this was what cam up( i posted in the 1st page ):
P0118
P0740
P0753
P0758
P0785
P1860
The ONLY code that doesnt come up this time when i scanned it was P0740 and all i did was put ignition power to the C2 connector to the pinout F2 cause it wasnt getting 12v ignition power.
Anything else i could try out, or what else could not be getting power? I shows the same codes but the one (P0740: Torque Converter Clutch Circuit )
when i start it, itll shift quickly through 1-3 and stay in 3rd the rest of the ride??
Old 06-26-2008, 08:28 PM
  #37
From searching those codes on this website, it would appear that the wiring harness might be messed up, meaning you might need to trace each wire and find a problem, hopefully...
Have you verified getting 12v at Pin E on the trans plug, ie the issue I was having?
Old 06-26-2008, 08:32 PM
  #38
wbwhiteboy's Avatar
yea its getting power now, from when performabuilt asked me. Thats pinout F2 on C2 connector that controlls that. i think everything else is getting power but im not sure completely. There only a few pinout on that fuse block that goes to the tranny. And the wireing harness looks good, i dont see anything pinched, and its wrapped up in the black tubing, and seems fine
Old 06-26-2008, 08:37 PM
  #39
wbwhiteboy's Avatar
Heck i had better luck when i had a LT1 4l60e hooked up to it, but i never did get to actuall y get it out on the road cause i must of when i was installing it i cracked the bellhousing and it broke off. But i had the LT1 tranny and stall and the car had *****, but now its sluggish when i hooked up the LS1 stuff.
If i turn the car off and punch it, itll spin the tires alittle, and then shift quickly. But when i had the LT1 on it, the car was making continous "S" shapes in the road. lol
Old 06-27-2008, 10:35 AM
  #40
wbwhiteboy's Avatar
bumping up for any advise now....?
Quick Reply: 4l60e Tranny not shifting?? Stays in 3rd?
