Help pick my gears... A4
I am currently running 3.42's and was thinking 3.73's or 4.10's..
The new cam I am putting in is 230/230 579/579 114..
I am thinking 4.10's.. What do you think?
If you want a better 60 foot, try working on your suspension.
I don't think there is anyone running 4.10's its too much gear. 3.73 is the max.
<strong> you might be getting worse times cause you're converter is hitting harder hence breaking traction that's why it seems like you are going slower.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">agreed. This is likely your problem.
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">maybe, but most A4's don't need a lot of suspension work until they have a lot of mods.
I don't think there is anyone running 4.10's its too much gear. 3.73 is the max. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Disagree.
A number of people use 4.10s and a few run 4.33s. 4.10s will be a good choice with that cam since it will want to rev high for best performance.
I wouldn't go over 4.10 for a daily driver because the rpms get too high on the highway. Personally I think 3.42s are probably the best if you do a lot of highway cruising. 3.73s aren't too bad for occassional highway trips and work well in town. 2500 rpm = 73mph.
<small>[ March 27, 2003, 07:01 PM: Message edited by: Ragtop 99 ]</small>
Depending on car weight you should be able to see low 1.6's out of that vig 3600 on et streets.
You should perhaps iron out the convertor swap before messing with gears.
To take full advantage of your powerband with that cam you will need 3.73's, and 4.10's would be optimal. This gearing works well with a 26X10 tire. I cross the traps at about 6500, give or take, with that setup.
Like ragtop said, you should consider what this will do to your highway mileage and traction on the street, but for driving around town the setup is fine (IMO).
MANY of us run 4.10s (or 4.11s like in my sig) <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
what size ETstreet you running?
<small>[ March 28, 2003, 03:18 AM: Message edited by: badass 2002 z28 ]</small>
