changing th350 WOT shift points
Old May 23, 2008 | 09:26 PM
One Bad Z's Avatar
Default changing th350 WOT shift points
Right now my th350 with a forward valvebody short shifts at WOT. It shifts at about 5200-5400rpms. Need it to shift at about 6000-6300rpms. I can manually shift it but we are having problems with the factory tach not keeping up. It will tag the rev limiter (set at 6400) before it even reaches the redline on the factory tach. I have a shift light set to 5500rpms but it never came on. I've turned the light way down just to make sure it works, and it does.
Also during part throttle it shifts too quick. When i pull out within 10' its already in 3rd. The shop that built the tranny removed the passing gear if tha makes any difference.
Part throttle shifts aren't a big concern to me because i mostly manually shift cruising around anyways. The main concern is the WOT shifts.
What are the fixes/parts i need?
Old May 23, 2008 | 09:34 PM
performabuilt's Avatar
LS1Tech Sponsor
You can start by turning the set screw in the modulator about 3/4 to 1 turn clock wise this will help some but most likley you will need a govenor recalibration kit TCI has them to change springs and weights to get what you want thats why I like electronic transmissions. Just do a little programing
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 23, 2008 | 09:51 PM
whytryz28's Avatar
Or you can get a manual valve-body and decide when you want to change gears, those are funnnnnnerrrr haha I love the one in my 69'.
Old Jun 22, 2008 | 09:19 AM
One Bad Z's Avatar
How many rpms is each spring suppose to change. I bought the B&M govenor kit but it's the exact same kit as TCI just a different name.
Old Jun 22, 2008 | 09:29 AM
9000th01ss's Avatar
It doesn't work off rpm it works off mph since the governor is driven off the output shaft.
You'd have to be pretty much psychic to predict over the internet how many rpm it'll change your application.
You just need to try different ones and find out, and take notes.
The inner weights will have more effect on wot shifts. The modulator effects mostly part throttle but it does boost line pressure turning the screw in. The kick down cable should be connected it effects line pressure and shift quality also.
Old Jun 22, 2008 | 09:42 AM
FLT's Avatar
FLT
LOL on the psychic theory. Good advice for sure. Remember one thing when changing weights in a governor, lighter weights will produce later shifts. It is really a trial and error process and will take some time to get it dialed in just right. Good luck. Vince.
