2-3 clutches
Old May 30, 2008 | 07:07 PM
chargedvx6's Avatar
Default 2-3 clutches
I'm getting a rebuild on a 4L60E and am unsure which way to go with the clutches for the 2-3. (3rd clutch?). Afaik there are choices of fitting from 6 up to 10 clutches. The 10 pack will have more surface area but alot of people are using the 7 packs, why is this.
Old May 30, 2008 | 07:34 PM
performabuilt2's Avatar
LS1Tech Sponsor
just go with the z-pack as far as the different stackups everyone builds thier trannies different.....for most applications the z-pack you cant go wrong
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
Old May 30, 2008 | 09:40 PM
SunsetOrangeZ's Avatar
+1 on the Z-pak. My tranny guy wanted to use those in my trans but they were on back order big time last year.
I have the Borg Warner high energy clutches in my trans now and they feel great.
Old May 31, 2008 | 02:58 AM
chargedvx6's Avatar
My builder is saying that he prefers the 7 pak due to the beefier steels. Should I press to have the 14 pack or do the 7s have their merits?
Old May 31, 2008 | 10:58 AM
performabuilt's Avatar
LS1Tech Sponsor
Its a builders preference but we have had excellent results out of the Z-PAK with some of our fastest cars and are you sure he dosent mean 8 pak since 7 is actually factory on the 65e and only one clutch more than the normal 60e
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 31, 2008 | 12:20 PM
FLT's Avatar
FLT
I would use either the factory 65 pack (7 clutches) or use the 65 frictions which are .062 with .078 steels. This will give you an eight clutch set up. I have been testing different clutch combo's for years and have had very good luck with the eight clutch pack. I feel that the factory clutches work just fine. A clutch is just what it is. If the hydraulics's are good they will work well. If the hydraulics's are not correct, then no clutch is going to last. I to am not a fan of the alto set ups because the steel plates are much to thin for my liking. That would be the 9 or 10 setups. The Z pack some have had good luck with it, but then again it uses very thins steels to mount the frictions to. I also have seen where the clutches wear funny on the first couple plates and the last couple plates in a very short time. Good luck on which ever direction you go. Vince
Old May 31, 2008 | 02:51 PM
Black X's Avatar
I use the 8 Friction stack up from Vince@FLT in my truck.
185 Passes ranging from 10.66-11.70 (3800lbs) in one year. Pulled it apart for a look during the winter and everything looks great. I replaced them anyway but will be putting the good used pack in my daily driver. I could have easily ran them for another season.
I am very Impressed with the 8 Friction High energy Setup.
