deep trans pan ?
Old Jun 4, 2008 | 11:26 PM
chevyz2801's Avatar
Default deep trans pan ?
is a deep trans pan worth getting if so whats the best one
Old Jun 4, 2008 | 11:35 PM
performabuilt's Avatar
LS1Tech Sponsor
Its helpfull in added fluid capacity, I like the OEM deep truck pan best myself
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 4, 2008 | 11:53 PM
cookba's Avatar
i bought a deep truck pan from FLT a couple years back on there recommendation when i also bought there transgo kit, servos and a couple other pieces.
Old Jun 5, 2008 | 06:29 AM
ChevyGoldfinger's Avatar
I have had the TCI and now have the B&M cast aluminum pan. Both are good pieces. Just remember when you go with any deep trans pan, to also go with the longer pick up kit. Good luck with whatever you choose, more fluid is always better.
Old Jun 5, 2008 | 11:37 AM
ShevrolayZ28's Avatar
How's ground clearance with the deep pans?
Old Jun 5, 2008 | 11:41 AM
cals400ex's Avatar
what is the weight difference between the aluminum and steel aftermarket pans, on average?
Old Jun 5, 2008 | 10:48 PM
98WsSick's Avatar
I have the tci deep pan and i wouldn't reccomend it for a lowered car. It is lower than my ory.
Old Jun 6, 2008 | 02:13 AM
x2 on the lowered cars.
If you put one on a car lower than stock, go for the steel one, at least it will bend.
You are only going to whack a cast aluminum one on a speed bump once real hard. That will be a horrble mess. Do some measuring.
Old Jun 7, 2008 | 09:43 PM
barnat's Avatar
i think the B&M was 4.125"and comes with a bung allready for the trans temp sensor!!
Old Jun 10, 2008 | 07:23 AM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
I have the B&M 3Qt deeper pan, installed on my stock height 2001 Z28, and I would not recommend it on a lowered car.
SteveC
Old Jun 10, 2008 | 10:19 AM
382ssz28's Avatar
I use a BTE aluminum pan. I feel the benefits are the extra oil, and it is somewhat of a girdle for strength. As far as ground clearance, it is even with my Kooks 3" ORY.
Old Jun 10, 2008 | 02:14 PM
omcar's Avatar
I have an LPW aluminum pan..works great
Old Jun 11, 2008 | 12:24 AM
jimmyblue's Avatar
Moderator
'02 Silverado pan, and use the truck filter.
Old Jun 21, 2008 | 08:52 AM
topdj-com's Avatar
anyone using a summit racing one, I have one I used to have on my Tahoe, I was thinking of putting it on the TA
Old Jun 21, 2008 | 12:54 PM
cals400ex's Avatar
that is the one i am going to get. i will get the standard sized pan since my car is lowered.
Old Jun 23, 2008 | 04:52 AM
sawedoff's Avatar
Cool
Go with the OEM truck pan. You don't have alot of weight because it is a stamped steel pan. I think the theory is that it adds volume to the system and therefore enhances cooling of providing more transmission fluid.
Then again you could go with a transmission cooler and the extra capacity needed for the lines, hardware would be another way of increasing the capacity and get real cooling because you'd have to add more fluid to the system.
