converter screwing up
Old Apr 5, 2003 | 02:01 AM
FrankSS's Avatar
Default converter screwing up
hey guys, a quick question for yall, maybe. my stock converter has been messin up lately, and i dont know what the deal is with it. i can be driving down the road and nail it, and the converter wont let me go any higher than say 3k rpm. and itll do that for a little while, then i put it to the floor again later, it will do as it should. what can this be? how to fix it? it has 85k miles on it also.
Old Apr 6, 2003 | 06:09 PM
highgear's Avatar
Default Re: converter screwing up
Stock Converter?
I would take it to a Chev Dealer and get a Tech II scan. Or get an Atap scan if you know someone that has one.
Is your fluid level correct?
Have you changed fluid? <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
Old Apr 6, 2003 | 07:02 PM
jimmyblue's Avatar
Moderator
I don't believe the converter is the problem
here. It sounds more like the trans is not
downshifting. The stock converter, at 3000 or
5000, is pretty well stalled and acting like
a 1:1 coupling. (or 1.05:1).
Old Apr 8, 2003 | 03:49 PM
FrankSS's Avatar
ive had atap on it and it hasnt set any codes or anything. i just changed the fluid, but i put in some that trick shift stuff. i think that may be the problem. but ya i could be driving down the road and itll be like it locked up but it wont accelorate for anything (w/pedal to the flor too)
