problem with trans !
Old Aug 23, 2003 | 06:11 PM
ls1blazer's Avatar
Default problem with trans !
no fluid going to the cooler . its as if its not pumping ! is the pump electronically controlled? have a schematic?
Old Aug 23, 2003 | 06:34 PM
Magnus's Avatar
LS1TECH Sponsor
Default Re: problem with trans !
pump is not electronically controlled, however the pressure solenoid is.
If no fluid at all is going to the cooler, don't run the car any more at all... its time to tear the trans apart.
Old Aug 23, 2003 | 07:53 PM
ls1blazer's Avatar
the trans only has 3,000 miles on it and was working perfect when it came out. It did loose almost all of the fluid during the swap . could the system just need bleeding ?
Old Aug 23, 2003 | 08:59 PM
ls1blazer's Avatar
would not putting enogh fluid in the converter cause this. I did loose a little fluid from the converter too.
Old Aug 24, 2003 | 09:36 AM
CRAZYCUBAN29's Avatar
what did you swap out. How much fluid did you put in
Old Aug 24, 2003 | 12:27 PM
TA/30th 1002's Avatar
Whenever the engine is turning the torque converter the trans pump should normally be pumping fluid.
The pump has to pick up fluid from the pan (sump), pressure up the torque converter and valve body.
Torque converter outlet fluid goes straight to the cooler the back to sump.
Excess valve body fluid dumps to sump.
The cold sump oil level will normally read 1" - 1 1/4" above the high hot level (STABALIZED COLD FLUID LEVEL ENG OFF) ... If the fluid level goes down with engine running *Your Pumping Fluid*
Like Magnus Say's: With enough fluid in the sump to pick up, a cooler line off and the engine running SLOW for just a FEW SECS!! ... Oil flow indicates *Your Pumping Fluid*
If this gets you going, Great. If you're not pumping fluid, well think back over your install and form a prognosis.
... Ron
Old Aug 24, 2003 | 04:07 PM
toxic99's Avatar
If you removed the converter from the tranny, then reinstalled it, you may not have put it in all the way. This will destroy the pump when you bolt the tranny up to the engine.
Old Aug 24, 2003 | 04:47 PM
XFiveLiter's Avatar
Does it go into gear?
Old Aug 24, 2003 | 08:12 PM
ls1blazer's Avatar
I destroyed the teeth on the pump! how much to fix?
Old Aug 25, 2003 | 09:18 AM
Magnus's Avatar
LS1TECH Sponsor
Check out my web page in the sig, i have a how-to to remove the pump.
BE CAREFUL though. You need to account for ALL broken pieces and you cannot scratch any of the surfaces up.
Old Aug 25, 2003 | 09:33 PM
toxic99's Avatar
That's what I thought.
Old Aug 28, 2003 | 05:26 PM
ls1blazer's Avatar
got it fixed! $135.
