No first No DTC
Old Jul 29, 2008 | 12:56 AM
99BlackTransAm's Avatar
Default No first No DTC
My first gear has been going in and out for some time now, after I put the trans go shift kit in, I took it back to the shop two times and they went in and out of the kit and said it is in there right, Then i did get the 1-2 selenoid fault, (I thought it was becuase of my 4000 Stall) So i cleared it with HP and everything was working well, The car sat for two days and when I went to drive it today I had no First gear and no DTC, So i replaced the "A solenoid" 1-2 and still no first gear.. As of right now I have the bat. unpluged and going to try it in the morning.. Anyone have anyideas what it could be? im going to be in PINKS:All Out in Denver aug. 9th so im on a time limit and Cash limit.
Mods are as is:
1999 Pontiac Trans Am A4:
Lingenfelter Performance Engineering Intake Lid
SLP Loud Mouth Catback
Pacesetter Long Tube Headers
Pacesetter Off Road Y Pipe
F.A.S.T 92mm LSX Intake
P.T.M. 92mm Throttle Body
TSP Custom Cam .651/612 239/244 111 LSA
4:10s
TCI 4000 Stall
Trans Go Shift Kit
BFG G-Force Drag Radials 275/40/17
my Tune is at
http://www.hptuners.com/forum/showthread.php?t=19244
and when it started is at
https://ls1tech.com/forums/automatic-transmission/926704-help-first-gear.html
Old Jul 29, 2008 | 08:57 AM
Gilbert@Ace Racing's Avatar
If it is not recording DTC's then it is not a monitored condition, or reporting for the fault has been deleted in the tune.
Based on the fact that this happened immediately after the Shift Kit installation I would have to say the problem is in the hydraulic control system. Does the shop that you took it to have extensive experience with high performance 4L60E's or are they a "local shop" who rebuilds them?
g
Old Jul 29, 2008 | 09:30 AM
Local shop who rebuilds them
Old Jul 29, 2008 | 11:29 AM
If they do not have extensive experience in diagnosing these transmissions, if they do not handle the Trans-Go kits each and every day, if they do not specialize in them it would be difficult to say that they would be the correct professionals to ask to help out in a case like this. Not a shot at them at all.... it's just that these units are not easy to take to the next level.
Feel free to give me a call... I wouldn't mind kicking it around with you. We might find a solution that would enable you to get to the race.
g
Old Jul 29, 2008 | 11:37 AM
well it lasted a month and a half when they did the trans go the 2nd time.. Then after we put the new cam in the whole thing started over.. Not alot of Fbody or 4L60E shops around my area that do that kinda work and know what they are doing.. Most of them are Mustang shops ect..
Old Aug 2, 2008 | 08:57 AM
well the shop took a look at the shift kit.. every thing is where it needs to be.. He is going to take the trans a part and see what he can find.. blahh.. How hard would it be to do a 700R4 swap? Its the same thing right?
Old Aug 2, 2008 | 10:36 AM
FLT's Avatar
FLT
A 700 is not the answer to your problem. I would suspect that you have a code that is being set that is keeping the trans from having first gear or an internal transmission issue.
Old Aug 2, 2008 | 11:06 AM
performabuilt's Avatar
LS1Tech Sponsor
A few questions,
1-has the car been tuned for the 4.10 gears?
2-Has the car been tuner for the 4000 stall?
3-have you tried deleting the test for PO751 and PO757 (assuming one of those was the code you got)
The fact you cleared the code once and it starting working correctly makes me wonder if one of these might actually be your issue,
Ask your shop if they have a schafter shifter box or break out box by chance they could verify the trans function with that also and that would tell you where to look also.
Regular trans shops generally know nothing about tuning for high stalls etc and will be chasing there tails trying to solve the issue
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 3, 2008 | 11:01 AM
Originally Posted by performabuilt
A few questions,
Yes, I did tune it for the high stall, and i set P0757 (756 on mine) and P0751 to -3 no report.. I dont think the shop has a break out box.. I think its computer too but Nothing shows up and I was all out of ideas so I let them go into it.. The Hptuners link has my Tune on it..
Old Aug 3, 2008 | 11:19 AM
LS1Tech Sponsor
If you would like I can send you plans to build a simple version of a schafter shifter of sorts so you can test if you want to totally eliminate the trans?
__________________
Call 888-744-6542
Old Aug 3, 2008 | 11:42 AM
Yes that would be fine
Old Aug 3, 2008 | 11:54 AM
LS1Tech Sponsor
Ok will work on a diagram and instructions later today hopefully will have then by this eve sometime
__________________
Call 888-744-6542
Old Aug 3, 2008 | 01:28 PM
FLT's Avatar
FLT
I wonder if there is an issue with the 1-2 shift valve in the shift kit. Circled in read in the pic below. This uses a modified valve that has a hole drilled in it and in the end of the valve should be a gold ball and then a green spring. Make sure that there is not debris or a chunk of metal flashing in the valve. I have seen brand new valves have crap in them from trans go. Also note that the line up is correct from left to right, the 1-2 shift valve spring(white/pink looking), the 1-2 shift valve, gold ball inside the end of the valve, green spring, and then the shift solenoid. Here is a picture of the line up.
Old Aug 3, 2008 | 01:47 PM
Oh wish i had seen that pic when i changed my 1-2 silinoid, I didnt see a ball but i did see a spring not sure what color it was.. Ill look into it when i call the shop on monday.
Old Aug 3, 2008 | 01:52 PM
FLT's Avatar
FLT
Sorry not to mention it sooner. Was just sitting here watching the Cubs game with the grill going smoking some ribs and just thought of it. My wife is bitching that I need to get off the computer and finish cleaning the inside of my sons TV. I hate being home! Let us know what you find. Vince
Old Aug 6, 2008 | 03:13 PM
well he drop the trans and the fluid was Black, Took it apart and my First and Rreverse clutch packs where burnt all up.
So would this make the trans go into limp mode?
Old Aug 6, 2008 | 03:28 PM
9000th01ss's Avatar
It should make the assembler go into limp mode.
No first and burned clutches means it was slipping and just going to second, limp mode or not.
Old Aug 9, 2008 | 10:56 PM
Well Turns out my First and 2nd gear Cluths where all burnt up.. Re built the trans.. 1000$, He said the Trans-Go Shift kit was junk.. He called Trans-go and they would not tell him how to fix it... So he put an extra spring in behind the 1st valve to keep 2nd gear from flooding and locking out first..(or something like that..)
Well He worked all night and got the trans in 1 hour Before i had to take the car to pinks..but i MADE IT! I wasnt picked but its ok it was still fun to be on the show!
Best time of 12.8 @ 106, I have more i just need to learn how to drive the car.. Thanks guys for all your info and help..
