TCI controller/4L80E issues
Older TCI controller
Hughes performance trans
Turbocharger engine
I have the gray box TCI controller and would like to see/talk about settings. I have had in the past an issue when shifting from first to second manually at WOT. The trans seems to go it into neutral, I let off and it shifts.
I have a hughes transmission which means the valvebody has been modified to boost pressures. I was told that some people have had issues with too much pressure after getting a modified valve body and making ecu adjustments, making the selonoid flutter.
Could someone maybe post screen shots of the line pressure graphs for me to see for reference?
The graphs and readings from PC only show you what the pressure should be based on estimated parameters . The 4L60E and the 4L80E have no internal pressure sensor.
Although its also possible your intermediate sprag is not holding
I think what I am asking for is reasonable. I have checked line pressure with the ecu disconnected.. (over 200psi )
TCI controller graphs for line pressure is based on pw and tps. Just seeing where others have theirs set could be a better option that using some tech guy from TCI that does not understand the software.......... Yes I called. No he did not know. He was more concerned to tell me that the new controller did away with those settings.
One thing I need to say is I have not made a WOT run since rebuild. I have made initial settings and driven the car to get shift firm-nest settings at normal driving. It seems fine except that 2-3 is quick but hard shift like the 1-2. Just looking for comparisons before doing the WOT test.
And you are right he did say that the old controller had too much adjustability to it and that was causing issues.
By the way, I was the one calling your shop last week for a valvebody. I was concerned that the valvebody was a problem and was looking to replace it.
