4l60-e Trouble shooting * pump?? *
Old Aug 13, 2008 | 04:34 PM
wbwhiteboy's Avatar
Default 4l60-e Trouble shooting * pump?? *
Well not sure what could be the main reason, but a guy i know put the tranny in his car and he said when he first started the car on stands the wheels moved. He put the car down ready to drive and the car does nothing but rev??
The tranny was full of fluid, would that mean the pump is bad?
Old Aug 13, 2008 | 04:41 PM
performabuilt's Avatar
LS1Tech Sponsor
Unhook a cooler line and start car if fluid does not spray then yes the pump is bad likely broken during trans installation from converter not being fully seated
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 13, 2008 | 04:42 PM
wbwhiteboy's Avatar
trans is out of the car now. Any way to test while out?
Old Aug 13, 2008 | 04:50 PM
LS1Tech Sponsor
look into the pump where the converter goes in if there are not two tags in there or they are laying loose thats the problem
__________________
Call 888-744-6542
Old Aug 13, 2008 | 04:53 PM
wbwhiteboy's Avatar
I can double check but you kinda have me lost on what your talking about?
Old Aug 13, 2008 | 04:58 PM
LS1Tech Sponsor
well you see the two slots in the converter well there are two tangs in the pump that they set on when the converter is not fully inserted its breaks them off. It should be pretty obvious when you look. If not take a couple pictures of the front of the pump and the converter snout and send or post them and we should be able to tell you.
__________________
Call 888-744-6542
Old Aug 13, 2008 | 05:12 PM
wbwhiteboy's Avatar
yea i looked in at the pump now and they are still there, I have pics of the pump. I took it out and split it. Heres a few pics of it. You can see the Tags also..
http://www.1320video.com/gallery/album52
Old Aug 13, 2008 | 05:46 PM
LS1Tech Sponsor
Well the pump rotor assembly seems fine, Its hard to tell though but from the last picture of the PR valve it may not be seated against the wall . But I am not sure if it isnt its close.
4 of 9
9 of 9
__________________
Call 888-744-6542
Old Aug 13, 2008 | 05:53 PM
LS1Tech Sponsor
Fluid looks pretty bad though. There may be some internal issues clutches etc from the looks of the fluid
__________________
Call 888-744-6542
Old Aug 14, 2008 | 04:23 PM
wbwhiteboy's Avatar
well i talked to the guy and he said when he took the lines off after the car was running that, there wasnt any fluid coming out of the lines..... so that makes me think the pump?
Old Aug 14, 2008 | 04:26 PM
LS1Tech Sponsor
Well I see no reason in those pictures why that pump would not pump , I would check that the cooler lines are not blocked does not make sense
__________________
Call 888-744-6542
Old Aug 14, 2008 | 08:25 PM
Loadre's Avatar
Who built the trans? Someone I know is having a similiar issue.
Old Aug 14, 2008 | 10:06 PM
wbwhiteboy's Avatar
i couldnt tell ya?? i have no clue
