Converting M6 to A4.... Need help!!!
Old Oct 10, 2008 | 05:54 AM
ThaRiddler's Avatar
Default Converting M6 to A4.... Need help!!!
Ok so im converting this M6 i just got to my stage 3 4l60e, what kind of roller coaster am i in for.... how much is this goin to cost me.... what is all needed to complete the job... Thanks guys for your help!!!
Old Oct 10, 2008 | 09:32 AM
performabuilt's Avatar
LS1Tech Sponsor
https://ls1tech.com/forums/automatic-transmission/200477-m6-a4-a4-m6-conversion-info.html
This should help
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 10, 2008 | 09:41 AM
Bryan @ Speed Inc.'s Avatar
it's not that bad at all as far as the work involved... but there are a lot of little odds and ends you have to get, and can add up.
M6 to A4 you'll need a new wiring harness (or conversion harness from speartech)
flexplate, torque converter, trans cross member, shifter/cable, trans dipstick/tube, trans cooler... you might need a new torque arm bracket depending on whether your auto trans has one or not (they're different from manual to auto).
Old Oct 10, 2008 | 11:06 AM
ShevrolayZ28's Avatar
For the money you'll spend on tuning and a harness, it might be worth considering an aftermarket controller ($700-1000).
...I'm in the middle of an M6 to A4 swap and I'm using a Compushift.
The work is pretty straight forward but the cost of small parts involved add up in a hurry.
Beyond that, do a search , there's plenty of info on here.
Old Oct 10, 2008 | 01:36 PM
ThaRiddler's Avatar
Well i appreciate all of your help guys...
Thanks again
