370Z: Failure
thats just retarded thats the 370Z Nismo comes with nissan calipers.....i used to own 2004 track edition 350Z and it came from the factory 6 fawking years ago with brembro's and it performed great around the twisties!
bwahhahaaaa awesome!!!!
Here is a quote from the article: "Eventually, the Lambo came alive when we really started pushing it and the track warmed up: Some of the rear-end grip went away, which allowed us to rotate the big Lambo into corners and get the power down sooner."
Notice that the car went faster as grip went DOWN. The most "planted" car is not always the best handling or the fastest. The ZR1 is faster due in large part to its handling (the straights showed if anything it had a slight power disadvantage to the lambo).
BMW ///M Nerd
Lots of cars experience brake fade. On a magazine rag doll car I wouldn't doubt the brake fluid hasn't been changed since it left the dealer. In which case it's been beat to death, and the brake fluid is probably junk. Those cars are like orgy ******, and just get passed around.
The 370Z is still a good car, with I'm sure a decent brake setup.
the braking issue has nothing to do with the calipers. The brakes are made I believe by akebono, which is like the japanese brembo. The brakes on those cars are pretty damn serious. but they must put ****** autozone pads on those things. With a pad change I doubt you'de ever have a problem even at the track
Try doing repeat 100mph+ of nailing the brakes with our stock F-bodies and see how soon you have no brakes. Maybe the first try. If you are driving a car on the road course you need road course brakes. If you go to the drag strip, you need drag tires. Same concept. I don't expect track brakes on a 35-40K car, maybe on a 50k car like a Z06.
Yet the Mustang GT didn't experience any dramatic fade, the pedal never even got close to touching the floor, and the car never crashed.
Track brakes should come on any car thats designed to be driven in a performance manner. Power is useless without control, and a large part of that control is brakes. Nissan sells you a $40,000 370Z with the NISMO package, which is basically the track pack according to the Nissan website. yet they equip it with a shitty brake system and inferior calipers.
My '08 Cobalt SS came with Brembos from the factory, there is no excuse for Nissan cheaping out on them.
Look at the Nissan GTR, Subaru STI, and Mitsubishi Evolution. All equipped with Brembos, even though Brembo is Italian and Akebono is Japanese. They wanted good brakes, not something thats going to fail after 2 laps, which is why they went with the best. Theres a reason Brembos are used on almost all high end performance cars, and its because they are top quality.
The brakes on the 370Z obviously aren't "serious", or the car wouldn't have crashed. Pads won't make the pedal drop to the floor either. The 350Z had track pads, and those brakes were still horrible. You honestly think all the other cars in the test were equipped with track pads?? No, they were equipped with OEM pads designed for street and light track use. Yet nobody else had this problem. Don't try and make excuses, Nissans entire brake systems are junk.
Interesting you should make that comparison, considering the Mustang GT in this test is equipped with basically the same exact brakes as LS1 F-bodies came with, being dual piston PBR aluminum calipers up front and single piston aluminum calipers in the rear. Same size rotors up front as well.
In one of my favorite old road and track articles a 2001 SS beat the M roadster, S2000, slk320 and boxster S around Thunderhill Park.
The z's brakes, harsh engine, and overall performance is embarrassing for a $40k car advertised as a track toy.
#35
Cheaper...could be...stupid? yes, IMO. You will end up modifying them both right? So, why go with the lower end of the spectrum when the higher end is a better "modding" base to start with. What you say is only true if both models (cheap and high end) share the same mechanics and the difference is cosmetic, if the best drivetrain and engine is in the high end model...why not getting that instead?
#36
#40
I thought they said the pedal went to the floor. Which is indicative of boiling brake fluid, and considering solids aren't compressible, its most likely what is at fault. I don't recall this happening with any f-bodys that were magazine tested. Not that it couldn't happen.
