Automotive News, Media & Press Television | Magazines | Industry News
motor trend dynos 2011 gt real results
Old 03-27-2010, 01:00 PM
assasinator's Avatar
Default motor trend dynos 2011 gt real results
http://wot.motortrend.com/6659607/au...v-6/index.html
2011 Mustang 5.0
3rd gear (1.69:1)
Horsepower: 365.26 hp @ 6600 rpm
Torque: 335.27 lb ft @ 4500 rpm
4th gear (1.32:1)
Horsepower: 377.99 hp @ 6500 rpm
Torque: 351.44 lb-ft @ 4400 rpm
2011 Mustang V-6
3rd gear (1.67:1)
Horsepower: 268.06 hp @ 6700 rpm
Torque: 249.95 lb-ft @ 4000 rpm
4th gear (1.24:1)
Horsepower: 267.11 hp @ 5800 rpm
Torque: 259.90 lb-ft @ 4100 rpm
wish they posted 1:1 results. they would be about 10rwhp higher, but would remove the stigma with not using standard practices.
Old 03-27-2010, 03:18 PM
kennyxg's Avatar
2011 Mustang 5.0 (4th gear pull, 15% powertrain loss)
Claimed horsepower: 412 hp @ 6500 rpm
Claimed torque: 390 lb-ft @ 4250 rpm
Actual horsepower: 435 hp 6500 rpm
Actual torque: 404 lb-ft @ 4400 rpm
2011 Mustang V-6 (3rd gear pull, 15% powertrain loss)
Claimed horsepower: 305 hp @ 6500 rpm
Claimed torque: 280 lb-ft @ 4250 rpm
Actual horsepower: 308 hp @ 6700 rpm
Actual torque: 287 lb-ft @ 4000 rpm
B
Read more: http://wot.motortrend.com/6659607/au...#ixzz0jQE7V9No
Old 03-27-2010, 03:33 PM
big dave's Avatar
Impressive numbers. It backs up the 395 rwhp that 1 magazine got on their dyno. Assuming that the higher number was produced on a dynojet and the Motortrend number was on a mustang dyno.
Old 03-27-2010, 04:04 PM
clint195's Avatar
I would assume they are both on a dyno jet but i could be wrong. Dont you have to figure in another 10-15% powerloss for the mustang dyno?
Old 03-27-2010, 05:16 PM
ThisBlood147's Avatar
Yea, what I've been told by dyno operators is that the Mustang Dyno is typically about 25-27% drivetrain loss compared to 12-15% for a Dynojet.
And I know alot of ppl are putting plenty of stock into these early dyno tests, but I'd say I'm more interested in real world performance (real acceleration times and cornering capabilities). FWIW, I think the 1:1 5th gear on the new Mustang is probably going to throw off alot of early amateur dyno tests until the operators learn about the new gearbox more.
Old 03-27-2010, 05:49 PM
djsanchez2's Avatar
Here are the specs form Ford on the trans, etc.
http://media.ford.com/images/10031/2...g_GT_Specs.pdf
Curious to see the 5th gear pulls.
Old 03-27-2010, 06:20 PM
deliveries will start trickling in 19th of april
Old 03-27-2010, 06:48 PM
clint195's Avatar
Thanks for the mustang dyno configurations. I knew it was higher than a dynojet but couldnt remember the exact %.. I am with you on the real world performance look of this.
Old 03-27-2010, 06:49 PM
clint195's Avatar
Reading the motortrend article it claims it was on K&N's dynojet.
Old 03-27-2010, 10:55 PM
Still pretty stout power numbers.....considering I had once predicted that the new 5.0 would only generate about 375 hp at the crank. Props to Ford to proving me wrong about their resolve to deliver a 400+hp GT.
Old 03-29-2010, 02:56 PM
got-a-ls1's Avatar
you cant translate dyno numbers to crank numbers and be perfectly accurate and use an arbitrary 15% number which is just a guess anyways. Besides now that we see some initial 1/4 mile results and the camaro and mustang are at the same trap speed i should say that puts the 395 rwhp to bed.
Isnt the ford SAE rated at 412 horsepower as is the LS3 SAE rated? i believe the SAE rating, not some BS numbers of a dyno, especially when it is K&N's dyno... thats how they get the 20 horsepower claims from their filters... lol
Old 03-29-2010, 03:08 PM
1969mach1's Avatar
i would like to see some real track numbers from regular everyday drivers.
what is weight of these cars?
Old 03-30-2010, 12:29 AM
LS1LT1's Avatar
Weight of the Mustang?
Apparently it will be roughly 3600 pounds for the manual and 3650 for the automatic.
Old 03-30-2010, 01:37 AM
King Nothing's Avatar
chevy better put the camaro on a diet!!!!!
Old 03-30-2010, 07:45 PM
Dom
Dom's Avatar
Wait, I thought the new Mustang had to weigh 4,000lbs due to the new safety equipment because that's what GM said made their car 4,000lbs?
Old 03-30-2010, 07:58 PM
guy the weight depends on equipment. mine will probably be very close to the 3605 as i ordered it. the rest will weigh a lot more.
Old 03-31-2010, 03:42 PM
RaggedRides's Avatar
What I don't understand is how it supposedly dynos very close to the SS and weighs a couple fat bitches less, yet runs and traps identical numbers. Granted they leave out 60ft times, but I'm willing to wager they're spinning with either car.
Old 03-31-2010, 03:46 PM
Possibly. The new GT is running on some skinny *** 255 tires......no performance tire option available either.
Old 03-31-2010, 03:54 PM
jmurray87's Avatar
What did the 2010 SS dyno stock? Manual and Automatic. They must be close I saw a guy take the auto SS L99 and ran a 12.9 which is rather good when u consider its the L99 not the LS3.
GM will be releasing spec info on the 2011 Camaro's in 8-9 days....
Old 03-31-2010, 04:27 PM
Nothing constructive, but that is a beautiful car. Ever consider swapping in an LSX down the road? If I had a V6 that clean and that color, I'd just keep it.
Quick Reply: motor trend dynos 2011 gt real results
