built my own engine mount
If you read it then why did you not know what mounts I had? Seems you forget things right after you read them. You simply implied the UUC mounts would reduce the wheel hop. I'm telling you they dont. Ask anybody on here that has some and they will tell you the same thing. You seem to know everything about wheel hop so when you figure out for yourself that the motor mounts do nothing for it maybe you can actually make something that does!
Just put nitto 275/35/18 nt555 tires on all four stock wheels and add pinion support and bmr wheel hop kit and u will then have no wheel hop...trust me this works...maybe its the tires or the combo but this set up worked for me....
Raven,
Let's agree to disagree. Since I just seem to know everything, and you CLEARLY know everything, I don't want your sensitive soul to get worked up again.
In the mean time, Kudos to Mighty...
