Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Maggy guys, anyone upgraded the heatexhanger?
Old 05-11-2009, 05:40 PM
raven154's Avatar
Originally Posted by onebadcad
Heard that too. If car has a good tune and good fuel, meth is not needed as a safety aide. Some people just like the security of such.
I have never liked the idea of spraying meth. I heard it helps in hi boost apps but I dont think I will see enough to warrant the need I guess. I now my maggie will be pushing some pretty hot air being that it is overdriven quite a bit I would like the safety thing of it. I just dont like the fact that you can run out of it. If you have to fill more than one tank to be able to go out and kick some ****, somethings just not quite right.
Old 05-11-2009, 05:48 PM
onebadcad's Avatar
I think the SnowPerformance website speaks of huge gains, like 70 HP, but I have never seen a Maggied car benefit. Maybe it applies to NA, not sure. BTW, you can always use your spare tire area for a five-gallon meth tank, unless of course that space is reserved for a turbo,,,
Old 05-11-2009, 05:55 PM
raven154's Avatar
Turbo shmerbo
Old 05-11-2009, 06:51 PM
Redneckbmxer24's Avatar
You obviously have been into blowers much longer than I so I'm not trying to get into a debate or anything because I would loose very quickly lol But from people I have talked to and and other V owners that have a maggie pushing 7 or 8 pounds say the meth helps.
How small of a shot would one need to spray to just cool the IAT? Meth is a lot cheaper to replenish so if it did any good at all it would be worth it. Its just now I have my wires crossed on positive displacement blowers and meth. Thanks a lot! lol
a littel 25 shot will be a nice boost cooler, you dont need much. either way the money would likely be better spent on a cam. you'll get a power gain and wont have to refill anything.
meth the up side is its cheap, the down side is it doesnt do crap on a positive displacement blower, especially one on very low boost.
nitrous the up side is it works, the down side is it runs out quick, and is expensive.
if you want lower IAT's while just playing around on the street get a larger heat exchanger, if you are running at the track you would also benefit from an ice box.
Old 05-11-2009, 06:52 PM
Originally Posted by TurboCtsV1
i would go with a 50/50 water-meth mix and it shouldnt hurt anything.
and it wont help either.
Old 05-11-2009, 06:54 PM
jerrad's Avatar
You gain by upping the boost/timing. If you only add meth you will see limited gains. In the buick world you add meth, up the boost to 25 up the timing to 23* and just fill the tank every 2-4 weeks.
I went to the track a couple months ago and used all of maybe 1/10 of a gallon after making 5-8 1/4 mile passes plus the trip there and back which were filled with many WOT blast.
Old 05-11-2009, 07:02 PM
Collections Ban
Hendrix-Engineering's Avatar
We have seen good gains using meth at the track.With that said i would not use it for a dd.This is with are maggie cars.
Old 05-11-2009, 07:54 PM
raven154's Avatar
Ah yes, meth and extra timing and boost is what I'm reafering too. Sorry. I know meth only will gain nothing if your tune is already spot on.
I am running 9lbs right now and after my pulley gets here tomorrow will be past 10 hopefully. By running meth I could increase the timing and be more aggressive with the tune but when you run out, its detonation time!
Old 05-11-2009, 08:35 PM
jerrad's Avatar
Yeah for sure. The kit I have has a low meth warning light. Then it has a light that turns red when the pump startes and switches to green when the pump reads a certain amount of pressure.
Like I said on Sat. though, the pump failed before I had the red to green light and I found out the hard way.
If you want to talk to the meth man go to the alkycontrol website and call Julio. He's made a ton of kits and knows everything about the + and - of a system.
Old 05-11-2009, 08:42 PM
raven154's Avatar
Thanks!
Are you still in town? If I get the pulley's on and make sure the belt doesn't jump again, I'd let you drive it. I didn't really want to get out on Saturday with the belt like that and get stuck somewhere.
Old 05-11-2009, 08:53 PM
jerrad's Avatar
@ Jarrad
I found my pulley problem! The damn bearing spun in the pulley and basically wallered it out. I have a new pulley on its way as well as a 2.7" blower pulley as opposed to the 2.8". It should get me past the 10psi mark considering I'm making 9 right now.
Which pulley was it?
Old 05-11-2009, 08:55 PM
  #32
jerrad's Avatar
Thanks!
Nope, made the drive back down on Sun. I understand man, I didn't want to throw a belt either so I was content with seeing the beast. When you swap to the 122 I get first dibs on the 112.
Old 05-11-2009, 09:01 PM
  #33
raven154's Avatar
It was the tensioner pulley and I actually did throw a belt that night! lol I shredded that thing. Came out in several pieces! Its got a 7 rib belt (its all Oriellys had) on it right now and parked. It made it home but I dont think that thing has much life left! lol Its a good thing we didn't take her for a spin! $185 later I have a new tensioner pulley and a 2.7" to throw on after work! I'm all giddy! I just want to see that gauge climb past 10!
Then in the meantime (the several months while I save for the 122 swap) I think I will go ahead with the 90mm snout as well.
Old 05-11-2009, 09:04 PM
  #34
jerrad's Avatar
Glad it was a cheap fix.
Old 05-11-2009, 10:17 PM
  #35
raven154's Avatar
Those are some decent gains with pcm actually tuned for it. Those are the kind of numbers I like to see. Thanks Nice!
Old 05-12-2009, 01:06 AM
  #36
blemoine02's Avatar
who makes the 90mm Snout?
And i bought a Cts-v with a maggie installed allready. Is there a jug to fill for the intercooler?
Im thinking about putting a ls2 Throttle body but need to find a snout to fit?
Old 05-12-2009, 05:29 AM
  #37
raven154's Avatar
Hendrix Engineering sells them for 140.
Dont forget you may need a tune to get the most out of it and you could run lean without the tune. Dont know for sure, Hendrix could tell you for sure.
Old 05-12-2009, 07:29 AM
  #38
DoctorNick's Avatar
I need to order the ls6 to ls2 harness for the TB and a TB. Should I go aftermarket with the TB or factory?
Old 05-12-2009, 07:42 AM
  #39
raven154's Avatar
An LS2 TB will be fine. I have a ported LS2 TB that I will be installing on mine. You can pick up the harness adapter from Texas Speed for like 50 or 60.
Old 05-12-2009, 08:17 AM
  #40
CTSV_510's Avatar
EPP has these, I assume they work with our LS6 but you might want to call to double check. $45.95
http://www.exoticperformanceplus.com....html?item=743
Quick Reply: Maggy guys, anyone upgraded the heatexhanger?
