Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
K and N intake on 06
Old 05-23-2009, 11:03 AM
chewy_mxer's Avatar
Default K and N intake on 06
Has anyone tried to get the 04-05 K and N full intake on the 06, I think they have a different size throttle boty, but I was wanting a K and N intake for my car, but they don't make one, will this work?
Old 05-23-2009, 11:21 AM
chewy_mxer's Avatar
I went rate to the K and N site and they got nothing on there, maybe they took it off, I can get a real good deal on this kit so thats why I want to pick it up. So is there a chance it will bolt up or no? thanks for the help
Old 05-23-2009, 12:21 PM
maxspeed96ct's Avatar
Originally Posted by TurboCtsV1
they make it... but we've all found out the hard way no gains
will be made other than a nice sukking noise. our stock airbox
is pretty dern good, and a k&n element works really well, just
fab the intake tube at the wrinkle and your gtg!
ive seen gains of about 10 whp, which isnt bad for under 300$
Also i was wondering if the GTO intake would fit if your worried about the TB?
Its almost exactly the same but im not sure if out the elbow on the ctsv has less room to turn. The GTO has a slight cut out but i think the v might have the room.
Old 05-23-2009, 12:59 PM
CTSV_510's Avatar
There is little room for the intake tube, I don't think the GTO on would fit.
The K&N tube will fit either LS6 or LS2 throttle body - the outside diameter of the TB are almost the same. The only difference for the '06+ is the extra hose connection.
Old 05-24-2009, 11:45 AM
chewy_mxer's Avatar
which extra hose connect is it? like would it effect it? if it bolts up i wana get it, but if it will hurt it i wont
Old 05-25-2009, 11:06 AM
CORNER CARVER's Avatar
GTO tube would probably hit the PS pulley. I am tinkering with a cold air setup will post results when in.
Attached Thumbnails K and N intake on 06-cold-20air-20tube-20ii-20techii.jpg   K and N intake on 06-cold-20air-20tube-20tech.jpg
Old 05-25-2009, 10:03 PM
CTSV_510's Avatar
smallest pics in the history of posting pics.
Old 05-25-2009, 10:05 PM
I cant realy tell, is that the K&n kit ?
Old 05-26-2009, 07:12 AM
Homemade.
This is my factory looking tube. I am working on an open element cold air kit that would eliminate the air box.
Attached Thumbnails K and N intake on 06-cold-air-tube-tech.jpg   K and N intake on 06-cold-air-tube-ii-tech.jpg
Old 06-03-2009, 12:50 AM
Z28MrJ's Avatar
My Buddy has a 06 V.. He put an 05 K&N on his. & he Keep on throwing a COde and he car was RUnning funny so we took it off.. ANy IDEAS>?
Old 06-06-2009, 03:36 PM
chewy_mxer's Avatar
I just got the 04-05 kit on my 06, runs fine, the what looks like the PCV valve or breather hose coming out of the valve cover, some sort of breather hose, I havent had any codes come up yet, but it does make a decent sucking noise, any info on that, and what have you guys done with that hose? I just zip tied a little piece of on old foam filter so it keeps stuff from getting in it
Old 06-08-2009, 03:14 PM
Cold air intake!!
Quick Reply: K and N intake on 06
