KARS Kit F/S
Yup. The DSS/Hendrix Engineering axles work great. I put the KARS kit on to protect the diff after the Maggie. I kept the KARS kit on after the axles to be certain all was okay. It's good, so the KARS can now go to another good home.
For me, because I left the Specter Werkes bushings in, the install was easy and took about an hour maximum with a pair of Rhino ramps (and I'm no mechanic). If you do the cradle bushings, add an hour or two to that since you have to lower the cradle a few inches to slide the bushings into place. If you have a lift and air tools, it would become MUCH easier and you could knock an hour off those estimates.
