Hendrix axle installed....it works!
Got it in yesterday and finished installing a little while ago, only install advice I can give is when you use a jack to unload the suspension...make sure the jack is dead center, originally I had it aft of the spring which cause the whole lower control arm to warp slightly which made getting the bolts out a PITA...only figured it out reinstalling on the trailing arm bolt...live and learn.
Either way as the title says it works! Went out, dry roads, 4k and dumped it...nothing can be felt in the car or seen in the aftermath on the road...but a chatter can be heard, not felt....and I have no other wheel hop fixes...no bushings, washers, kars...nothin...so I'm very happy...total cost with shipping is ~380...40 to ship each way. In looking at the stock bar next to the hendrix one it doesn't look that much bigger to me...didn't measure it but who cares, it worked!
I think skull already said it still hops...which kinda sucks cause the only time I really like to spin the tires is in the wet...simply because it doesn't chew the tires up too bad....this is florida so I suspect it won't be very long till I can try her in the rain...I'll let ya know.
