**New Design CS Mounts and LS7 Clutch install**
#42
Sorry guys for the late response,I totalled the car last year.Very important thing I did that I forgot to mention is that I ended up changing out my Diff fluid with AMSIOL gear oil 75w-90. That helped alot with the whinning.I strongly suggest you guys switching out the Heavy A$$ Flywheel that comes in the CTS-V......Stock LS7 Single Clutch or any Single Aftermarket Clutch will work as long as you go with a lighter flywheel.NO Shimming required when using a LS2/LS3/LS7 Slave cylinder....You can use the stock slave but you need to shim it....Another thing that was annoying was the stock CTS-V shifter. Get rid of that!!!
