Navigation Screen Tilted
Hello V Owners,
I have an annoying issue with the navigation system in my 05 V. The problem happens when using the map in 'heading up' view or 'bird's eye' view. When I turn a corner the map does not do a very good job of centering itself. It always seems to over rotate or under rotate by several degrees. So even though you are going straight down the road the map does not show the road straight up and down it shows it tilted.
In the attached picture I am on a perfectly straight road (most roads in Phoenix are) and I have been traveling dead North for nearly a mile. As you can see the map is tilted to the right even though the compass in the upper left hand corner shows north as straight up.
Any of you ever have this issue? This head unit has been replaced twice by the local dealer for unrelated issues so this is the third nav unit to have the exact same issue so I don't think it is a problem with the head unit. I also have the latest nav disc (part# 09320NA) and both discs have the same issue. If I left out some troubleshooting info please let me know. Any help would be greatly appreciated. Much thanks in advance!
~Brian
~Brian
Does that road run exactly north/south. If not, then it looks like you have the nav set up to orient itself that no matter which way you are pointing the map will always stay oriented north. Not sure thats what it is, but try cycling map views to see if the others do the same
You need to set the map up to go off your heading and not north. That little compass up in the left hand conner means it's oriented north all the time so most likely the roads around you are not perfectly set up to point north south east and west.
I just leave mine in the view where you are looking from behind the little triangle. I can see the upcoming roads a lot easier. But never had a problem with it in the birds view like you have it.
Thanks for the info guys.
Yes, the road I am on is solid North / South. However, the nav system does the same thing when I am headed any direction. I am under the impression that when the nav system is in 'heading up' mode that it will put the heading up no matter my direction of travel, meaning that the red triangle representing the car will point up at all times. I used this picture because it illustrates my issue very clearly with the compass and the map out of sync. I have other cars with nav systems and all of them show the road straight up and down. If I am missing the boat on a simple setting or a calibration procedure please let me know how I can adjust that.
Again, I appreciate your help and feedback.
~Brian
~Brian
One too many doughnuts have been done in your V... You knocked your GPS into dizzy mode. In order to cure it you have to do an equal number in the opposite direction and post videos on youtube.
Look at the nav screen picture (the little button that changes the view), it's on heading up...press the button again and it'll go into north up, then 3d...the only calibration I know of is to reset your location....I don't think there's a compass recalibration since the car has nav and will technically auto recalibrate itself....Like I said, mine does this sometimes, bring it back to the dealer and get another nav if it bothers you.
After looking through the service manual it seems like there might be some hardware in the rear package tray next to the sub... I don't know much about this but I do know this is driving me nucking futs....
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
I agree 100% that is exactly what I had to do on mine....the only downside is that it cost me a set of rear tires in the second month of owning the car..... and the local PD took my camera which we were using to document this for R%D purposes only....but they didn't buy the story...cool guys but they did make me pick up trash @ the parking lot @ the boat ramp that we were using for our research project....I laugh everytime I look at the marks....that and it was my sister's camera!
