Comp mode vs turning off TCS
I'm in the same boat as JD_Z28. Mine is all stock and will show when everything is fully off (after holding down for 5+seconds), but I have never seen CM come on the screen after I pushed the button twice in less than 5 seconds.
Help!
LAW
Help!
LAW
I think there are a couple of things like TPMS that can prevent vehicle from going in to CM but mostly likely cause is that your radio isn't programmed correctly for the V. A dealer can do it with a tech II
If yours is truly a virgin (I'm doubting that ...looks like a total **** to me), then it may not be the radio programming causing your issue. I doubt they would mess that up right from the factory but this is GM we're talking about lol.
its just like a normal button press, and i dont hold it down.
So what happens to the traction control options when u go to an aftermarket radio? I was assuming everything still works like normal just not able to be displayed on the new unit. Surely I can't be stuck with the stock head unit!?
i could be wrong though.
I'm 99.9% positive that you cannot get in to CM without the stock head unit; however, if you replace our nav head unit with the standard cts head unit (non-nav DIC), you can still get in to CM and retain all other functions. On the other forum there is a thread where someone wanted an aftermarket nav head unit so they hacked up the console and used a standard cts non-nav DIC so all stock features could be accessed (including CM) and used the extra space for a pioneer nav head unit or something. It looked super nice and clean and worked out very well for him.
#33
To me the competitive mode is still too restrictive. Mine kicks is very often in CM, and I don't even think I'm sliding much. Still, I don't usually turn it all the way off.
The car will occasionally make a violent sideways movement when I speedshift 2-3, and I'm not sure if I would lose it without stability control. I wish it would start in CM, and that CM would free it up a little more than it does.
To get into comp mode I hold the button for like 15 seconds. Screen also tells me Stability system is off.
