Prothane "Six Shooter" driveshaft couplers
You most likely have an alignment issue with the drivshaft then. The stock one will flex and hide the imperfection that the revshift one will not. On the other forum there is discussion on shimming the drive shaft or transmission for proper alignment. Or it could just be a shitty part. It happens.
A sagging transmission mount is a major cause of coupler failure,both OEM and aftermarket.When the rear of the trans drops down due to a worn mount, the transmission output shaft is no longer in a straight line with (or pointing directly at) the pinion on the rear diff. With this misalignment the coupler is now being expected to act like a U-joint, this is not what it was designed to do, the flexing back and forth as the coupler rotates is one thing that can kill the OEM couplers prematurely (the constant use of a lead foot is the other cause), the stiffer aftermarket couplers really hate this flexing action. A new transmission mount or shims will get the trans output shaft back to its original height and pointing directly at the rear diff pinion. The shims are a cheaper fix, but will be an "as required" trial and error type of affair.
This is 100% correct, we learned it the hard way. The factory coupler is soft and will mask drive line alignment issues. Our coupler won't tolerate a drive line that is out of alignment either.
I just installed the creative steel trans mount and very happy with the results. Great product, dealership was stumped when they put in new trans and couldn't explain why shifting was still hard and some gears just couldn't be selected at time. All of that is fixed with the trans mount. I should have bought this 2 years ago.
Here is a picture of the creative steel installed and I am holding the stock one up for comparison.
That is great tech info killernoodle. However, I'd rather support Max and CS. There are so few vendors supporting the aftermarket V1 community with decent products, giving my money to Prothane would be like a drop in a bucket. I think there is a nominal price diff between Prothane, Revshift, and Creative Steel, so consumer cost is not much of a factor.
the point was that CS has done more for the dead platform of the V1. That is why they deserve the support. No ones knocking rev shift .. the more aftermarket vendors the better but last time i checked they don't offer a bolt 8.8 rear end option. CS just has more invested into the V1.
