CTS V Z06 Clutch
I do have a set of OEM wheels with PS2 tires ... anybody wanna buy them?
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Man! Had a BUNCH of PMs in my mailbox. Well, I let it go to the first guy. If it falls through (and he doesn't want to pay the UPS bill), I'll let everyone know. He's a good guy, so I really don't think that'll happen.
I do have a set of OEM wheels with PS2 tires ... anybody wanna buy them?![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Ok. I'll contact one of them. Or... U could pm me a price. Just trying to decide if I should keep my current stage 4 competition clutch kit or sell it new before I install it to go with the LS7 kit or a monster kit....
I'm very interested in getting more info about this setup as my clutch is starting to slip. I looked to try to PM ecotec88fiero, but I might not have enough posts to send PMs? Does this setup work on the LS2?
#32
Odd, I couldn't PM from home, but I could from work?
I haven't driven a standard is ages, nor have I driven a high perf standard. Are there any other clutch management tips? I know things like don't ride with your foot on the clutch (only time my foot touches the clutch is to shift), stuff like that. Am I missing anything else?
When backing up into my driveway, I never fully release the clutch, always about halfway, feathering it a bit, sometimes giving it a lil more gas to get up the not smooth transition from street/driveway. I figure this isn't helping.
#33
Darn I'm in Los Angeles otherwise I'd hit you up to install mine before I swap the engine and trans into my 67 camaro. I'm wondering how hard could it be with everything out of the car???
#34
It depends on what bell housing you use. If you have a V bellhousing it will. But if you are using an F-body bellhousing you need to use the F-body slave. The master you use will also determine what slave you use because the connections on the C6 and V are different from the C5 and F-body slave. From the sound of it, you have a whole pull out from an F-body. A lot of people have installed the LS7 clutch in the F-body and have used the stock slave. Some may need a small shim under the slave. I would check out the manual trans section here on the board. Lots of good LS7 swap info in there.
#38
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
