Joined the OBX header crew -Pics-
I'm talking about stainless steel brushes that were used on carbon steel prior then used on a stainless piece...Even scotchbrite pads will carry over the iron oxides from the carbon steel and embed them into the metal...Will it cause crazy corrosion? No, probably not...but, if you want to avoid any potential, you always isolate stainless 'tools' from carbon steel 'tools' ('tools' being wire brushes and so on) Same thing goes with using steel wool on stainless parts...
I put my OBX with resonators on about 4 months ago. The color is gold/blue from heat, exactly the same as my Ducati ST-4. Pretty sure the Italians don't use cheap stainless on those machines!
