MPG's ridiculous after cam install....
#41
on the highway i manage to pull around 27mpg cruising. but if im heavy with the pedal it goes away quickly.
OP are you now heavier on the gas since the cam? that would hurt your mpg more then anything.
#42
I am very conscious of pedal position and what rpm I shift at, always between 2-3k, sometimes skipping gears if doable, and once I hit 45 mph it goes into 6th. Right now my average on the head unit shows 10.7... A joke if you ask me. These cars are cool and all, but not 10.7 average mpg cool...
Like I said. I'm going to play hard ball with my tuner. I want the car tuned closer to 13.2 at WOT with 12.5-8 at peak TQ.
As far as part throttle tuning goes, there has to be some modifier table that you can tune on while going part throttle below a certain RPM range, say 2,500 that allows the car to run leaner. He is a good tuner no doubt. I just don't want to **** him off by saying his tune suck cuz my car is getting 10mpg's when I drive it like my mom drives her camry lol
He tunes with EFI Live if it matters, is there any specific questions I can ask or things to suggest that might get him thinking??
Thanks for all the input guys...
#44
You can command the car to run at a leaner AFR across the board ASSUMING the VE,maf, and injector tables were tuned correctly which they GENERALLY are not if you havent spent any time on the street logging and tuning. The only way to do this correctly and safely is tuning on the street.
#45
I knew this post was coming.
It's because he disabled your o2's and your running open loop.
As most have mentioned here, go to another shop and get your MPG back.
If you insist on sticking with FF then tell them to put the o2's back in and tune it for closed loop. If they can't figure out how to make the o2's work. Then again your working with the wrong shop.
#46
#47
#49
with your mods 10 mpg .....no way ..... I get 12 overall & 15 if I drive like I have a little sense, And I still get 21 on the highway......... Thats with a ProCharged
864 whp ___________ Time for some more better tunin I think
#50
punishment, no it's his primary, he is a member on another board I am a member on and he posted that info there.
right now according to his post on the other board the car has no functioning o2's and is running open loop.
#51
Still you should get more than 10mpg. My V with a 224 cam still averaged upper teens.
Your tuner can try playing with the O2 switch points.
#52
Just left the shop. The 02 extenders were at fault. They're working now, and are functioning normally. We went on a 15 min drive while the tuner watched everything he said everything is dead on, nothing looks out of place. Excuse my lack of knowledge here, but once the 02's were up and going they were only correcting +/- ~5%, which he said was a good thing. I guess meaning the tune was so good the 02's are only needing to correct a very small amount. He said the MAF looked good during our trip and it was giving the proper amount of timing as well...
I'm gonna drive it for a week or so and see what happens. I was dead empty and put 4 gallons in today, did one WOT 2-4 pass and the rest city driving in 45mph zones. Fuel warning came on at 38 miles. So I figure just about 10mpg.....
Yikes.... Hopefully it gets better.
#54
#55
He said he didn't have to change anything in the tune because everything was fine, after 15-20 min of data logging on the street.
